Author Topic: Multiple instances of pcsxr help  (Read 1351 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: July 11, 2013, 04:32:12 am »
I'm trying to run multiple instances of the ps1 emu pcsxr each with different configs but for some reason the configs are all linked together even though the instances are in different folders. The reason for this is most lightgun games work fine using nuvee guncon plugin for both players but there is one game "Die Hard Trilogy" that needs to have the first controller set as "nuvee pax pad" and the second controller as "ssspsx pad" to work". If I have only one instance config setup for die hard no other lightgun games work with 2 players, if I have only one instance config setup for 2 player lightgun games then die hard doesn't work.
I've tried fresh copys of the emu in different folders but just cannot the configs to stay separate  :dizzy:
Connorsdad
Re: Multiple instances of pcsxr help
« Reply #1 on: July 14, 2013, 04:11:59 am »
Bump
It seems there's quite a few different instances I'd need for different light gun type setups.
Anyone have any ideas how to make the configs stick ?
Connorsdad
« Reply #2 on: July 14, 2013, 09:51:05 am »
So I found out that configs are stored in the registry so it isn't possible to have more than one config, I also found out that I can change the controller config by using command line switches to launch the games.
How would I do this in hyperspin ?
