Author Topic: Degausing coil???? Do I have one?  (Read 1835 times)
Lilwolf
« on: November 14, 2003, 11:18:15 am »
I have an Ergo 27" VGA monitor (that many on the board have).  It has some 'issues' mainly in the top left corner having a color spot..
I noticed that there is a cord around the outside that looks like a degausing coil.
whats the chance there IS a degausing coil on it and I just don't know what button to push?
Last... where do you get the magnetic wire that you need to build the Oscar type degausing coil?
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:Degausing coil???? Do I have one?
« Reply #1 on: November 14, 2003, 12:25:42 pm »
There isn't one on the Eygo, I have the exact same one.  I just went out and oredered a degaussing coil and it cleared up my monitor perfectly, I had pincushioning and discoloration "issues" in the top left and lower right corners and they went away immediately.
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« Reply #2 on: November 14, 2003, 02:05:30 pm »
Pulled from another post
"The instructions were to take the corded drill (sans bit) and start about 6 inches from the monitor. Start the drillmotor very slowly and watch the monitor degauss. I was skeptical at first, but, it worked like a champ!"
Nailz
« Reply #3 on: November 14, 2003, 02:24:53 pm »
Yeah, I tried that with mine, and couldn't get it to work.  I also tried doing it with a blender like someone suggested to no avail.  The degaussing coil worked like a charm the first time thru for me.
