Author Topic: Does anyone have x64 drivers for this?  (Read 13207 times)
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« on: July 08, 2013, 04:05:44 pm »
I have the Gamemon Universal USB converter I purchased back in 2007. I know Futime released x64 drivers but I can't find them anywhere Google etc.. And I don't think this compay is around anymore. I'm sure someone else here has this adapter and possibly has the x64 drivers? Thanks!
JDFan
Re: Does anyone have x64 drivers for this?
« Reply #1 on: July 08, 2013, 05:04:11 pm »
Not sure if this pack includes 64 bit drivers but it is v1.2 of the drivers (only working link I could find) wouldn't hurt to give them a try : ( http://199.91.153.58/m9y7gsrqbwqg/yn0xtzyi2mm/gamemon1.2.exe ) -- Checked the installer and it at least opens on a 64 bit OS so might work.
Hunk_4TH
« Reply #2 on: July 08, 2013, 06:53:04 pm »
Thanks man that worked like a charm!! :)
YagiHige
  • Last login:May 11, 2016, 03:17:10 pm
« Reply #3 on: May 11, 2016, 03:17:43 pm »
I know this topic is old, but none of these worked for me, but a single youtube video comment did, and I wanted to spread it to a few topics.
The following is what I did on my Win7.
1. Driver link: http://www64.zippyshare.com/v/4wXxacht/file.html
2. Google how to disable driver signing enforcement.
For Win7, go to Start menu and type cmd.exe in the Search Bar and press Enter. (Remember you must be logged on as Administrator - if you're not, logout from your current user and login as Administrator. Or right-click the "Command Prompt" link in the start menu / accessories and select "Run as Administrator") Now type the following and press Enter:
bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
3. Now run the setup to install the device drivers. Win7 calls the device "Composite".
Optional: Win7Pro, go to Start -> Run -> GPEdit.msc
Now go to User Configuration -> Administrative Templates -> System -> Driver Installation -> Code signing for drivers
Click on "Disabled", then on "OK".
