Author Topic: fooling with m2emu network  (Read 232341 times)
Dozer316
  • Last login:October 09, 2025, 02:47:49 am
Re: fooling with m2emu network
« Reply #120 on: September 12, 2014, 10:07:36 pm »
Hey there, many thanks for the info - Looking forward to trying this out.
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
« Reply #121 on: September 21, 2014, 03:42:29 am »
I think we're leaving overlook an awesome job, someone tried the tool "lag fix" online??
Nuexzz
« Reply #122 on: February 04, 2015, 03:22:25 am »
HERE I'M BREAKING THE HEAD BETWEEN BOTH LOCAL, REMOTE ETC  :banghead:
anyone here knows how to do magic (m2lagfix) in only 1 pc and 2 instances of m2emulator ?
SailorSat
  • Last login:January 23, 2026, 04:28:07 pm
    • For Amusement Only e.V.
« Reply #123 on: February 04, 2015, 06:58:27 am »
--- master
Code: [Select]
[Network]
RxPort=8001
NextIP=127.0.0.1
NextPort=8002
FrameSync=1
--- slave
Code: [Select]
[Network]
RxPort=7002
NextIP=127.0.0.1
NextPort=7001
FrameSync=1
--- m2lagfix
Code: [Select]
[m2rx]
LocalHost=127.0.0.1
LocalPort=7001
RemoteHost=127.0.0.1
RemotePort=8001
StallDetection=1
[m2tx]
LocalHost=127.0.0.1
LocalPort=8002
RemotePort=7002
[m2stats]
RemotePort=-1
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Nuexzz
« Reply #124 on: February 04, 2015, 12:21:30 pm »
cool thanks works great!  :applaud:
if someone wants to do some tests with m2lagfix online so I'll be on this server http://irc.lc/freenode/m2lagfix/user , if it works well we can think about doing a nice interface to communicate in races.
something?
Nuexzz
« Reply #125 on: February 05, 2015, 12:17:24 pm »
Help SailorSat! we can not communicate by the rules of the tool m2lagfix (we are using the old online tool using an external program vpn "hamachi" to avoid opening ports).
here I leave you in attachment configurations of each machine
SailorSat
« Reply #126 on: February 10, 2015, 10:57:42 am »
Oops, didn't see you post until now... I'll take a look at it once I get home.
Nuexzz
« Reply #127 on: February 13, 2015, 01:57:21 am »
you are far from home haha :laugh2:
SailorSat
« Reply #128 on: February 13, 2015, 11:41:53 am »
your m2lagfix.ini has a broken [m2rx] header.
Boomslang
  • Last login:January 01, 2024, 08:20:43 pm
« Reply #129 on: April 11, 2015, 08:12:33 am »
any updates to this at all sailorsat? I'm not very patient haha. Love hearing of cool new finds
SailorSat
« Reply #130 on: April 11, 2015, 12:59:00 pm »
Nothing new here for now. I'm in the process of converting my (every damn time broken) Daytona USA cabinets to PCs
Boomslang
« Reply #131 on: April 12, 2015, 02:27:30 am »
ah I happen to be doing the exact same with Sega Rally 2 Twin cabs. Just spent last 2 days working on them so ill have these as 3p and 4p to go with my Daytona 2 twin ive already converted. Hope it goes well for you
jacklance
  • Last login:August 18, 2015, 02:18:53 am
  • Geek
    • None
« Reply #132 on: August 18, 2015, 02:19:24 am »
It's been a week or so, and I still get "107" when I try starting up the game. Meanwhile, everyone else is talking about how they can play the game, and it seems like Sega's continuing with updates and new outfits now. Is IbVPN my only option now?
vandale
  • Last login:September 11, 2024, 07:07:45 am
  • Id 10 and t error
« Reply #133 on: June 21, 2016, 06:11:36 am »
m2lagfix was intended to be wrapped around "any" m2em instance.
I wrapped it around all of my m2em instances.
Hi SailorSat. Just stumbled across this and since I am upgrading my cab I decided to finally get rid of the buggy connection between my M2 units.
Arrghhh, I cant get it to work, please check my settings. I have 2 separate machines, Gb LAN connected, currently links ok with some flickering on rival cars when not using m2lagfix.
Any help is appreciated as I cant get them to link with your wrapper
--- master
[Network]
RxPort=9001
NextIP=127.0.0.1
NextPort=9002
FrameSync=1
--- slave
[Network]
RxPort=9001
NextIP=127.0.0.1
NextPort=9002
FrameSync=1
--- m2lagfix
Master
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemotePort=9001
[m2tx]
LocalHost=127.0.0.1
LocalPort=9002
RemoteHost=10.0.0.2
RemotePort=9000
Slave
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemotePort=9001
[m2tx]
LocalHost=127.0.0.1
LocalPort=9002
RemoteHost=10.0.0.1
RemotePort=9000
SailorSat
« Reply #134 on: June 21, 2016, 10:14:33 am »
Hm... I remember running into similar issues - try replacing 127.0.0.1 with 10.0.0.1 on the master, and 10.0.0.2 on the slave
If I remember correctly, UDP on 127.0.0.1 did work fine on my Win7 development rig, but not on my XP64 rig in the cab.
m2network.ini - master
Code: [Select]
[Network]
RxPort=9001
NextIP=10.0.0.1
NextPort=9002
FrameSync=1
m2lagfix.ini - master
Code: [Select]
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemoteHost=10.0.0.1
RemotePort=9001
[m2tx]
LocalHost=10.0.0.1
LocalPort=9002
RemoteHost=10.0.0.2
RemotePort=9000
m2network.ini - slave
Code: [Select]
RxPort=9001
NextIP=10.0.0.1
NextPort=9002
FrameSync=1
m2lagfix.ini - slave
Code: [Select]
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemoteHost=10.0.0.2
RemotePort=9001
[m2tx]
LocalHost=10.0.0.2
LocalPort=9002
RemoteHost=10.0.0.1
RemotePort=9000
vandale
  • Id 10 and t error
« Reply #135 on: June 21, 2016, 07:08:54 pm »
Thanks I will give it a go tonight, your a star.
SailorSat
« Reply #136 on: June 24, 2016, 05:35:13 am »
Did it work?
vandale
  • Id 10 and t error
« Reply #137 on: June 24, 2016, 03:45:28 pm »
Did it work?
Hi, got caught up with bg4 trying to format widescreen correctly, will have a go today
vandale
  • Id 10 and t error
« Reply #138 on: June 25, 2016, 12:56:33 am »
Did it work?
Hi, no it didnt.
Now due to BG4 I am running the IP addresses 192.168.69.251 (Master) and 192.168.69.252 (Slave). M2 works fine in linked mode and then I try the following for m2lagfix and they just dont connect, am I doing it wrong, is there a special startup sequence? I am just running m2 then the m2lagfix exe's one after the other:
--- master
[Network]
RxPort=9001
NextIP=127.0.0.1
NextPort=9002
FrameSync=1
--- slave
[Network]
RxPort=9001
NextIP=127.0.0.1
NextPort=9002
FrameSync=1
--- m2lagfix
Master
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemotePort=9001
[m2tx]
LocalHost=127.0.0.1
LocalPort=9002
RemoteHost=192.168.69.252
RemotePort=9000
Slave
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemotePort=9001
[m2tx]
LocalHost=127.0.0.1
LocalPort=9002
RemoteHost=192.168.69.251
RemotePort=9000
« Last Edit: June 25, 2016, 12:59:25 am by vandale »
SailorSat
« Reply #139 on: June 25, 2016, 04:25:44 pm »
Like I explained earlier, don't use 127.0.0.1 - use the local address (192.168.69.251 on master, 192.168.69.252 on slave) :(
P.S. I see myself "patching" some ROMs soon ^^
Nuexzz
« Reply #140 on: June 26, 2016, 06:50:19 pm »
"but consider m2lagfix obsolete soon"
you think replacing m2lagfix for a patch for each game?
« Last Edit: June 26, 2016, 07:14:21 pm by Nuexzz »
SailorSat
« Reply #141 on: June 26, 2016, 08:43:15 pm »
No, I plan on replacing the "master" mode in the games.
It seems the master mode is causing like 90% of all problems.
However, not every game allows to choose between master and slave - those games need to be patched :)
vandale
  • Id 10 and t error
« Reply #142 on: June 27, 2016, 05:21:40 am »
Hi, got it working, thanks for being patient! Looking forward to your next public release. ElSemi would be so proud.
Regards
Gene
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« Reply #143 on: June 27, 2016, 10:29:51 am »
Hi Vandale, can you post how was it configuration (working now), because
I'm pretty hard to learn.
SailorSat
« Reply #144 on: June 27, 2016, 05:08:59 pm »
I am currently investigating into the advanced link fix.
So far done:
External "Master"-Token generator and packet throttle.
--- PPS = packets per second ---
Daytona USA - shows rock solid graphics with 58 pps - cars start flickering if more than 60 pps
Indy500 - was one of the games that was basically impossible to link up with more than 2 oder 3 units - with the fake master and a packet limit of 58 pps the game stays in sync and the link stays stable. If I increase the packet limit to 60 pps (or more) the game almost instantly shows "network error".
MotorRaid - behaves basically the same as Indy500.
ManxTT - doesn't seem to care about packets at all, it just works fine with any speed.
Sega Rally - the pointers on minimap seem to flicker with 58 pps - the flickering disappears with more than 60 pps, however the countdown still goes crazy in any case.
Last but not least, Sega Touring Car does not seem to work at all - Without the tool, it simply won't link up at all - With my tool it will link up, but sit in network check forever.
I am pretty sure the network should be closer tied to the framerate, however I have currently no idea how exactly that is supposed to work.
Boomslang
« Reply #145 on: June 28, 2016, 02:31:44 am »
awesome SailorSat!
very cool to get link finally working in IndyCar, i was having issues with that :(
SailorSat
« Reply #146 on: July 04, 2016, 08:07:51 am »
Guess this one will be a little harder as I thought.
Can't get it working on the actual cabinets - need to "hook" VSync and pause the emulator (which in turn slows down emulation speed).
SailorSat
« Reply #147 on: July 07, 2016, 05:20:19 pm »
So it turned out, I cannot hook the vsync the way I wanted to do.
However there still is light at the end of the tunnel :D
Small LUA patch to "disable" the infamous "NETWORK ERROR" in Indy500 and Motoraid - turns out the code has some "delay" counter going up till 0xFF, and then deeming the network unreliable. By writing 0 (read ZERO) to this counter every single frame we can be sure to never reach that value. - Not exactly the way I wanted to fix things, but still should be enough to get a "stable" 8 player setup running.
indy500d.lua
Code: [Select]
require("model2"); -- Import model2 machine globals
function Frame()
I960_WriteDWord(0x00555214,0x00000000)
end
indy500.lua
Code: [Select]
function Frame()
I960_WriteDWord(0x005ec6b0,0x00000000)
end
motoraid.lua
Code: [Select]
function Frame()
I960_WriteDWord(0x005195d4,0x00000000)
end
« Last Edit: July 07, 2016, 06:35:39 pm by SailorSat »
SailorSat
« Reply #148 on: July 10, 2016, 03:51:30 pm »
First test on my daytona setup was good, although some questions remain.
Indy 500 with the ROM patched, (but without the new link fix) works good, as long as all machines can keep up with 60 FPS. - It gets even worse than Daytona if machines can't reach full speed. - Most of the time I try to overtake an NPC car, they instantly "teleport" into my car and crash me.
With the new link fix, that doesn't happen, but the game will slow down for everybody to the lowest machines speed. (which is fine if they can run at 60fps)
I still can't get a "reasonable" netplay in Sega Rally though, even with only 2 machines and the link fix, the timers go crazy. The problem seems to be buried deeper inside the network boards.
Haven't tried other games yet.
vandale
  • Id 10 and t error
« Reply #149 on: July 11, 2016, 01:23:30 am »
Hi, do we use the m2lagfix and the LUA script? Thanks
SailorSat
« Reply #150 on: July 11, 2016, 02:34:38 pm »
you can use the lua with m2lagfix, yes.
SailorSat
« Reply #151 on: August 28, 2016, 11:42:13 am »
Bam... Indy 500 has another serious problem xD - the game simply freezes (as does it in MAME) :(
baritonomarchetto
  • Last login:Yesterday at 02:19:44 am
« Reply #152 on: August 28, 2016, 04:00:38 pm »
Keep the work up Arianne!
buttersoft
  • Last login:Today at 04:34:23 am
  • Is running at 15kHz
« Reply #153 on: September 02, 2016, 12:38:19 am »
Agreed! Amazing efforts so far, we're all itching to play more model2 and model 3 games over network! It feels so close, though I imagine even with your skillset it's still a lot of work. You have my thanks.
eldiego
« Reply #154 on: October 30, 2016, 06:18:53 pm »
Hi, i am trying to use the m2lagfix but with this config start only master with link system (but for 1 player) and slave continue searching...
Master
[Network]
RxPort=9001
NextIP=192.168.1.3
NextPort=9002
FrameSync=1
m2lagfix.ini
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemoteHost=192.168.1.110
RemotePort=9001
StallDetection=1
[m2tx]
LocalHost=192.168.1.110
LocalPort=9002
RemoteHost=192.168.1.3
RemotePort=9000
Slave
[Network]
RxPort=9001
NextIP=192.168.1.110
NextPort=9002
FrameSync=1
m2lagfix.ini
[m2rx]
LocalHost=0.0.0.0
LocalPort=9000
RemotePort=9001
StallDetection=1
[m2tx]
LocalHost=192.168.1.3
LocalPort=9002
RemotePort=9000
I have only 2 cabs connected via lan, Ip master 192.168.1.110 ip slave 192.168.1.3
Please If anybody can help me.
Boomslang
« Reply #155 on: October 30, 2016, 11:49:26 pm »
Master
[Network]
RxPort=9001
NextIP=192.168.1.3
NextPort=9001
FrameSync=1
Slave
[Network]
RxPort=9001
NextPort=9001
FrameSync=1
m2 network should look like that on each machine. Read back on SailorSat instructions earlier in this thread
eldiego
« Reply #156 on: October 31, 2016, 12:14:45 am »
Master
[Network]
RxPort=9001
NextIP=192.168.1.3
NextPort=9001
FrameSync=1
Slave
[Network]
RxPort=9001
NextPort=9001
FrameSync=1
Ok tomorrow will try.
I read 10 times or more but i m not ever understand...for the english i supose.
eldiego
« Reply #157 on: October 31, 2016, 05:42:39 pm »
Works fine!!!. thanks
FaithLes2425
  • Last login:December 06, 2020, 02:48:15 pm
  • Bingo!
« Reply #158 on: July 28, 2017, 10:59:22 pm »
Does the m2lagfix work across multible PC's?
What cabels are required?
Can i run through a switch/router or do i need a crossover?
Are there any limits to the lenght of the cabel/cabels?
SailorSat
« Reply #159 on: July 29, 2017, 11:57:49 am »
Sure it does.
You can (in theorie) even use it online.
