Author Topic: Marquee installation  (Read 2949 times)
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« on: July 05, 2013, 07:53:06 am »
Hi all,
I hope the images explains my issue more than I can in words!
From the side of the cab the top will not be horizontal but will have a degree of angle.
I don't know much about this part, so could anyone advise me if its best to cut the panels so they form vertical edges, or can it be done without.
Hope that makes sense!!
edekoning
  • Last login:Today at 04:39:20 pm
Re: Marquee installation
« Reply #1 on: July 05, 2013, 08:16:23 am »
Well my cab only had the bottom at an angle, and I just used a regular aluminium L-bracket. You can see the results here: http://forum.arcadecontrols.com/index.php/topic,119175.msg1366215.html#msg1366215. I think it looks good, and it is hardly noticable, but that's because its all black on black :)
I know that others have used plastic retainer that are curved, so then the angle doesn't matter at all.
mcseforsale
  • Last login:August 14, 2025, 10:40:54 am
  • Creepy Mario Dude
« Reply #2 on: July 05, 2013, 01:25:39 pm »
You'll want to cut the pieces so that their perpendicular to the ground, otherwise your marquee will look hack.
Here 'ya go.  $1.98
http://forum.arcadecontrols.com/index.php/topic,117977.msg1268459.html#msg1268459
AJ
« Last Edit: July 05, 2013, 01:29:38 pm by mcseforsale »
UFO
« Reply #3 on: July 05, 2013, 02:31:11 pm »
@edekoning - Looks good - and it is definitely not easy to tell, I had to look closely at what you did... Your cab is cool too.
@AJ - Got ya... I think this might be the way to go. God knows how I'm going to cut the angles - I only have pretty basic tools, jigsaw etc... will need some thought!
mcseforsale
  • Creepy Mario Dude
« Reply #4 on: July 05, 2013, 02:43:21 pm »
I used my circular saw (most of them can cut up to 45 degrees).  I matched the angle using one of these:
http://www.homedepot.com/p/Empire-9-in-Polysteel-T-Bevel-130/100156737#.UdcTg5wQN1U
Then I transfer that to the saw blade and make sure that my measurements are to the correct side of the angle.
AJ
UFO
« Reply #5 on: July 05, 2013, 04:27:57 pm »
Thanks for that AJ - I figured that would be the way to go ... I'll have to see if I know anyone locally that could help out.
I haven't seen one of those adjustable squares since woodworking at school!
AJ
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #6 on: July 08, 2013, 10:24:58 am »
I also matched the angle with the same thing AJ did but I used a table saw then to cut it.
Dalgaard
  • Last login:April 05, 2015, 01:42:14 pm
« Reply #7 on: July 08, 2013, 01:52:27 pm »
I made a small drawing trying to explain what I mean ;)
kahlid74
    • GamersAnon
« Reply #8 on: July 09, 2013, 10:00:53 am »
Yes yes, this makes sense.  So I do the bottom, because it should be 90 degrees to the ground, and then I use aluminum angle, and I created a press.  So I tak a 2x4 and then a 3/4" MDF and screw it down over one side of the aluminum angle.  Then I bend the aluminum angle until it gets to the right angle that the bottom/top need.  GO SLOW.  If you go fast it will warp and look awkward.  Small little pulls down the bend the aluminum.
StragoRx
  • Last login:July 05, 2014, 05:56:09 pm
« Reply #9 on: July 11, 2013, 11:33:34 pm »
Sounds crazy but I did something similar with plastic corner protectors from home depot. I took an angle finder and found the angle of the bottom part of my marquee (non-90 degree) and cut a duplicated angle out of a strip of ply. I placed the ply angle pointing up on my gas grill and pressed the plastic down with hot mits until it conformed to the correct obtuse angle. After it cooled, I spray painted it black and screwed it in, looks great.
kahlid74
    • GamersAnon
« Reply #10 on: July 12, 2013, 09:53:21 am »
Yeap.  No matter how you work it either you'll have to bend the Metal/Plastic to fit your angle or get to a pro machine shop and have them bend it for you.
UFO
« Reply #11 on: July 14, 2013, 07:22:41 pm »
Thanks for all your tips on this chaps...
Think I'm going for the 90° to the floor option. I'll have to see if my local wood supply will help me out with the cut...
Sent from my GT-N7105 using Tapatalk 2
mcseforsale
  • Creepy Mario Dude
« Reply #12 on: July 14, 2013, 08:28:47 pm »
Actually, what you can do is measure using an existing board.  Just temporarily install the board and just set the base of the saw manually by eyeballing it.
AJ
