Author Topic: Rock-ola Princess has no power to the selector buttons  (Read 2265 times)
Mikey Bordner
  • Newbie
  • Last login:July 04, 2013, 11:43:57 pm
« on: July 02, 2013, 09:16:58 pm »
I recently bought a Rock-ola jukebox. The selector buttons seem to not have any power. I don't anything about jukeboxes, so I don't know where to start. If you select a record by switching a pin on the wheel, it will play fine. But other then that, nothing works. What could it be? I checked all the fuses I could find, and pushed the reset breakers. Nothing I did makes the selector switches work?
ed12
Re: Rock-ola Princess has no power to the selector buttons
« Reply #1 on: July 02, 2013, 09:52:17 pm »
there should be a switch inside the box
black slider,1 side is normal play the other is service.
service should allow for u to make selection's
if this is not going on,then inside the control unit is a .63amp fuse,if it is open
this will cause it,also on the same note if it is open u need to have that unit serviced
on the unit is a control solined,they tend to pack it up
live link here
jukebox-li​st-request@​lists.netlo​jix.com
they are very good ppl,reg and ask
ed
