Author Topic: Use a PC monitor in a video game?  (Read 964 times)
dpdelcollo
  • Last login:February 17, 2004, 11:06:39 pm
« on: November 14, 2003, 02:00:19 am »
Ok, so read the great article here on BYOAC about how to hook up your arcade monitor to run of your PC, can I do a similar trick to get a PC monitor to run off the arcade?  I need to test where the problem is with the video not working on a machine that I can hear is playing.  I don
paigeoliver
  • Awesome face!
Re:Use a PC monitor in a video game?
« Reply #1 on: November 14, 2003, 02:34:57 am »
The answer is yes, and no.
Yes it can be done, but you will spend more money doing it than an arcade monitor would cost.
You would need a scan convertor that supported rgb, ground + sync. That would cost more than an arcade monitor.
Only exception is some of the OLD Amiga and PC monitors (not the kind with VGA plugs, the kind with the plugs that look like serial port plugs.), which will work just fine, only thing required is some dodgy wiring. But only SOME of those work. Offhand I think I remember that the Amiga 1080 monitor works.
Anyway, you DON'T need an extra monitor to troubleshoot what is obviously a monitor problem. All that is going to do is tell you that there is something wrong with your arcade monitor.
Guess, what, there is something wrong with your arcade monitor.
There are many troubleshooting guides for arcade monitors on the net. Tubes are almost never bad, so I suggest doing a cap kit, and replacing the flyback. Chances are good that those two will bring it back to life just fine, and it will probably never need another repair.
StephenH
« Reply #2 on: November 14, 2003, 11:33:54 pm »
You will need a scan convertor to do it.  They are expensive.
However, if you find a TV with a SCART connector (which is a european standard, so it is hard to get in the US), this connector can be used to turn a TV into an arcade monitor.
You can also go with a RGB to component or S-Video convertor, and connect to a TV, but this will degrade the picture quality some.
