Author Topic: Question Regarding How to close a game from Hyperspin  (Read 2342 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: June 26, 2013, 11:51:25 am »
Does anyone know how to set up how to exit a game after launching it from hyperspin? (specifically Mame)
When I just open up mame by itself pressing the Esc key closes down the game, but when I open Hyperspin and open a game from the front end, I can't figure out how to close down any games... Its kind of annoying to have to control alt delete each time.. If anyone knows please let me know. Thank you.
Dalgaard
  • Last login:April 05, 2015, 01:42:14 pm
Re: Question Regarding How to close a game from Hyperspin
« Reply #1 on: June 26, 2013, 11:57:48 am »
Im pretty sure its a normal configurable option in Hyperspin? I've set mine to two buttons at once, A+B, to avoid accidentdal exits midgame. I think its just ESC by default...just like Mame.
05SRT4
  • Check out my Pow Pow
« Reply #2 on: June 26, 2013, 12:00:37 pm »
Yep you need to go into hyperHQ and setup the exit in there also for more advanced features you can edit the hyperlaunch script and edit the exit option in there. you may need to download AHK in order to do so. Also if you do use hyperlaunch you need to configure hyperspin to do so. Someone please correct me if i am wrong.
Yourname942
« Reply #3 on: June 26, 2013, 01:49:46 pm »
where do you set it up in hyper hq? Esc doesn't close games atm.
EMDB
  • Project RetroCade
« Reply #4 on: June 26, 2013, 04:06:04 pm »
Closing games is no Hyperspin setting but just an emulator setting. My MAME is set to close a game with ESC (the default). If I launch a game from Hyperspin and I hit ESC I return to Hyperspin as expected.
If you run MAME using HyperLaunch (a wheel setting in HyperHQ) quiting a game can be configured differently. Try to set it to Normal.
keilmillerjr
  • Web Developer.
« Reply #5 on: June 27, 2013, 12:03:30 am »
Pressing escape works for me as one would assume. Review your settings in hyperhq. You might want to disable hyperlaunch and see if that works. I have it disabled.
