Author Topic: I-PAC2 vs. KADE  (Read 3633 times)
PTD
  • Last login:August 26, 2014, 10:54:16 am
I-PAC2 vs. KADE
« on: June 23, 2013, 11:50:24 pm »
What is the advantages and disadvantages of the I-PAC2 vs. KADE ?
Is a single KADE unit be able to be use for a 2-player cabinet?  Do I have to buy two KADE units for a 2-player cabinet ?
Are both the I-PAC2 and the KADE compatible with Hyperspin with all types of emulators and PC games ?
keilmillerjr
  • Web Developer.
Re: I-PAC2 vs. KADE
« Reply #1 on: June 24, 2013, 12:15:12 am »
The Kade is only programmable via windows.
The Kade is made with one player in mind.
The iPac2 is programmable via windows, linux, and mac.
The iPac2 is made with 2 players in mind.
The iPac4 is the same as the iPac 2, but with 4 players in mind.
The keywiz is only programmable via windows.
The keywiz is made with 2 players in mind.
The lono2 is made with 4 players in mind.
The lono2 comes with a premade harness.
The mini pac is made with 2 players in mind.
The mini pac can also handle a spinner and trackball as well.
The mini pac comes with a premade harness.
I assume you can use wine or virtualbox to program windows only devices if you are using another os.
  • Online Online
  • Last login:Today at 07:04:08 pm
Re: I-PAC2 vs. KADE
« Reply #2 on: June 24, 2013, 03:34:51 am »
Number of inputs:
IPac2 - 32
KADE - 20
Type of encoder:
IPac2 - Keyboard
KADE - Keyboard, UHID Gamepad, several custom firmwares for consoles
Shifted functions:
Available on both encoders.
Cost:
KADE costs a bit less and if you are handy with a soldering iron, the KADE firmware can be used to program a Minimus AVR for even greater savings.
Depends on the number of buttons and whether you want to use shifted functions.
If you want Joystick + 6 buttons per player (20 inputs) and several shifted admin buttons, you'll only need one KADE.
If you want Joystick + 6 buttons per player and several dedicated admin buttons, you'll need two KADEs.
Yes.  As far as the computer is concerned, the encoders are keyboards -- or a gamepad if the KADE is programmed with that firmware.
