Author Topic: IPac2 Happ Coin Door Problem, Help [SOLVED]  (Read 1222 times)
Kevinem82
  • Last login:July 25, 2013, 10:55:14 am
« on: June 10, 2013, 12:24:02 pm »
I have a coin button, but I'm also trying to wire the coin door, I'm grounding the ground with the arcade ground for each player. And putting the power with the coin and push button together.....not working out for me
I read another users post and it actually worked! Here is his post his name is Arcades r fun
______________________________________________________________________________________________________
I'm not the best on these boards for this kind of help but here's my experience from past work.
When I first started out wiring coin doors I kept having issues with the coin door microswitchs.
The panel top credit buttons would not work while the coin door buttons were wired.
Turns out the middle terminal of coin door microswitches hold the ground not the outer terminal. After this change the credit buttons on the panel top and the coin door buttons worked.
Maybe this will help you or I'm just rambling because it's time to get some shut eye.
Good Luck,
Jack
And that was it normally the pos is in the middle but was on the top and the negative was in the middle.
Problem Solved : Insert Coin and Ca-Cling Press Start!!!!! Thank you this forum is awesome!
« Last Edit: June 10, 2013, 12:41:26 pm by Kevinem82 »
  • Last login:February 03, 2026, 06:27:46 pm
Re: IPac2 Happ Coin Door Problem, Help [SOLVED]
« Reply #1 on: June 10, 2013, 12:41:56 pm »
