Author Topic: Monitor driver Needed  (Read 1816 times)
batman
  • Last login:January 27, 2004, 08:15:00 am
« on: November 12, 2003, 12:21:49 pm »
hey guy i purchased a 27 inch wells gardner monitor off ebay. I can only get a picture of 640 by 480  on it, i know i can get up to 800 by 600 i just don't have the right drivers. does anyone know where i  could find the driver, this monitor is beige and was manufactured in 1998. i believe the model number is mw-27000 thanks
paigeoliver
  • Awesome face!
Re:Monitor driver Needed
« Reply #1 on: November 13, 2003, 05:55:22 am »
Monitors don't have "drivers" per se. They have definitions, which basically is just a list of the resolutions and refresh rates that the monitor supports. If setting windows to 800x600 at 60hz doesn't work, then that monitor doesn't really support that resolution.
Most of older (pre 2000) VGA arcade monitors I have seen only only officially support 640x480.
It might possibly support an 800x600 interlaced mode, which you may be able to get going using a video card utility.
Personally, I wouldn't even want to think about risking a nice 27" monitor by trying to drive it outside of its specs. 640x480 a pretty sweet resolution for gaming anyway. (Except for Real Time Strategy games, but who plays those on a cab anyway?)
batman
« Reply #2 on: November 13, 2003, 10:04:25 am »
 thanks for replying.  The person that i purchased it from told me that he used it at 800 by 600. he may be wrong. i think 640 by 480 is the wrong resolution because everytime i open a new application, the whole screen shake a little and resizes.do you know how i could do this interlace thing
paigeoliver
  • Awesome face!
« Reply #3 on: November 14, 2003, 12:40:51 am »
If it is truly a VGA (has a computer monitor plug on it), then 640x480 is the right size. Make sure you are also running it at 60 hz and not any higher. The resize thing could be any one of a number of issues, I would really have to see it in person to be able to tell.
Also, make sure all your Mame games are set to 60 hz too.
Producer
  • Last login:November 10, 2006, 07:49:47 pm
    • IMHz
« Reply #4 on: November 14, 2003, 04:52:04 pm »
In windows, go to control panel, display.  Settings advanced, and monitor.  Under this area you can force (in most cases) display at 800x600 to 60 hz.
FYI, I use a eygo monitor.  I wrote a review on my site about it, www.imhz.com/mame, however the 640x480 resolution is getting to be a pain in the *(&#.  next year I will be buying a good monitor that will do at least 1024x760.  I just been putting it off due to the $$$.
