Author Topic: Can you parallel controls?  (Read 864 times)
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« on: November 11, 2003, 11:49:44 pm »
For instance I have a 2 player control panel, but install dual top fire sticks to play Battlezone/Assault.  Can I wire these to the same encoder inputs as Joy 1 and Joy 2?
I don't see any reason why not, other than if someone grabs one of the other sticks while I'm playing it will mess me up!  I thought you guys would know for sure.
Jakobud
  • Last login:November 11, 2025, 01:07:55 am
Re:Can you parallel controls?
« Reply #1 on: November 12, 2003, 12:18:23 am »
Yes folks do this all the time.
hazydave
  • Last login:November 08, 2003, 03:53:29 am
  • "Hazy" Dave
« Reply #2 on: November 12, 2003, 10:09:51 am »
It's fine for most switch configurations: the controller board pulls the input line to VCC (usually +5V for keyboard contollers), any number of switches can be hooked up in parallel to bring the signal low.
You can't parallel trackball/spinner inputs. If you want to share these between multiple devices, the best way is to use a multi-pole switch in-between the two devices (say, spinner vs. trackball, if you want both but your controller only supports one at a time).
-Dave
eightbit
  • My cab is never done...
« Reply #3 on: November 12, 2003, 10:17:18 am »
The biggest example of this is probably the dedicated 4 way stick. Many people do that and its wired to the same inputs as p1's 8 way joystick. Player 1 can then use either stick to play depending on if they wanted 8 way or 4 way.
