Author Topic: Recommendations for cheap Groovy Arcade rig build?  (Read 2354 times)
Spicules
  • Last login:July 29, 2017, 11:40:33 am
« on: May 25, 2013, 02:20:51 am »
Looking to build a rig for my arcade cab that is good enough to run Groovy  Arcade at full speed, BUT as cheap as possible :D
My current rig is an AMD 3000+, MSI K8MM MB, 1gb ram, w/ AGP Arcade VGA.  It ALMOST runs all the 2D games at full speed/ sound sync, but not quite in GA.
I got the MB, HD and vid card for about $70 total.  I had a spare ATX case, 300W psu, ram, and DVD drive from an old, broken rig I had lying around.
As far as MB/CPU/RAM and Vid Card, what would be a cheap setup that would everything well?  If I could get 3D games going, that would be great also.
Calamity
  • Moderator
  • Last login:Today at 04:45:26 am
  • Quote me with care
Re: Recommendations for cheap Groovy Arcade rig build?
« Reply #1 on: May 28, 2013, 06:21:27 pm »
Hi Spicules,
I believe a Core2Duo is the minimum to be on the safe side. Anyway, pick Intel rather than AMD. The difference in performance with MAME is great.
Steps to create a log:
NightSprinter
  • Last login:June 17, 2018, 08:59:56 pm
« Reply #2 on: May 28, 2013, 11:21:17 pm »
It may be several months down the road (like, later this year), but I'll be moving my current test install to an AMD A-10 based system (with an integrated Radeon 6670).  Once I've got it built, I'll post performance results.
It doesn't matter how bad things are, it'll work out in the end.
