Author Topic: J-Stick with X-Arcade USB upgrade kit  (Read 4953 times)
Maccy
  • Last login:May 27, 2025, 02:20:45 pm
« on: May 20, 2013, 04:33:17 pm »
Hi,
I'm a total newbie and sorry for my "engrish".
Due to a little misunderstanding (my fault) with X-Arcade guys I've bougth 2 of these (I only needed one):
http://www.xgaming.com/store/x-arcade-adapters/product/x-arcade-usb-adapter/
I already own an HotRodSE but I want do build, with the help of a friend of mine that is expert in woodwork, a smaller control panel. I wanted to use the x-arcade adapter with a J-Stick from Ultimarc. Before bothering Andy directly, does someone know if j-stick and the x-arcade adapter are "compatible"? In case they aren't, what I have to do to make them work together?
Thank you in advance.
Marco
  • Last login:Yesterday at 08:00:19 am
Re: J-Stick with X-Arcade USB upgrade kit
« Reply #1 on: May 20, 2013, 04:49:34 pm »
It will work with any joystick that uses microswitches.
A switch is a switch is a switch, regardless of brand.
A lot of people swap out the joysticks in their x-arcade panels for better ones.
Maccy
« Reply #2 on: May 21, 2013, 04:44:51 am »
Ok, what I meant if harness like this (similar to the one found in x-arcade usb upgrade kit):
http://www.gremlinsolutions.co.uk/products/daisychainharness.htm
is directly pluggable in microswitches of Sanwa JLW.
My doubt is due to some photos of Seimitsu LS32 (I know, it's a different product) where I see a single cable coming out from the pcb
http://img.diytrade.com/cdimg/545775/11439113/0/1260872266/Seimitsu_Joystick_LS-32-02_LS-32.jpg
« Reply #3 on: May 21, 2013, 09:04:34 am »
It uses the same .187" connectors as the x-arcade sticks.
Maccy
« Reply #4 on: May 21, 2013, 09:14:10 am »
Thank you very much.
  • Last login:Today at 08:04:18 pm
« Reply #5 on: May 21, 2013, 12:12:40 pm »
The other thing to remember is that there are several models of LS-32.
The plain LS-32 uses regular microswitches.
The LS-32-01 and LS-32-02 use a different style of switch soldered to a PCB with a 5-pin connector.
Maccy
« Reply #6 on: May 21, 2013, 02:30:09 pm »
[cut]
Another thing very useful I didn't know!
Thank you.
