Author Topic: 1/2" MDF - strength?  (Read 3896 times)
barfybuffet
  • Last login:November 17, 2003, 10:37:08 am
« on: November 11, 2003, 02:42:14 pm »
I was going to go with 5/8" MDF but I can only get 1/2" and 3/4" locally.
I am mimicing Scott's Unicade style cabinet. My plan is to make the sides, bottom, and top of the control panel out of 3/4" MDF, these will be screwed into a 2x4 frame. the rest of the panels along the front and back will be made out of 1/2", mainly to make the cabinet lighter (and cost less). Will 1/2" be strong enough? My main concern is I want to mount a Happs over/under coin door on the front panel.. will 1/2" be able to support this?
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:1/2" MDF - strength?
« Reply #1 on: November 11, 2003, 03:13:29 pm »
Strength should be no problem, the 2x4 framing is porbably overkill so you can use 1/2 MDF. My cab, although smaller, is made of 1/2 with a few 1x1 reinforcements and it's quite sturdy.
eightbit
  • My cab is never done...
« Reply #2 on: November 11, 2003, 03:18:44 pm »
I'd say 2x4 is overkill, rip them in half and go 2x2 or like papa said 1x1's would work. My local home depot actually sells 2x4's cheaper than 2x2's, go figure.
1/2" should be fine in a home environment and its going to be much lighter to move around. The coin door isn't that heavy and as long as no one trys to bust into it 1/2" will be fine.
SNAAAKE
  • -Banned-
« Reply #3 on: November 11, 2003, 03:20:33 pm »
You should use 3/4" wood for coin door.I used 5/8" and I thought things would be fine but NO ! >:(
http://www.imagestation.com/picture/sraid67/pd47afca6a1f9b9b00b96a16457498d15/fbcd4d5a.jpg
Look carefully,I had to use some wood piece to make things work.
(looks great from the outside and all)
eightbit
« Reply #4 on: November 11, 2003, 03:43:11 pm »
Snaaack you need some wire tires to clean up that cable mess!
He is indeed right, most coin doors will be sized for 3/4" and you'll likely have to shim it in place. Though you might get lucky with yours and have it fit.
Jakobud
  • Last login:June 30, 2025, 02:20:39 pm
« Reply #5 on: November 11, 2003, 10:00:11 pm »
Why would you make the sides and bottom of the control panel out of 1/2" and make the top out of 3/4" ?
SNAAAKE
  • -Banned-
« Reply #6 on: November 11, 2003, 10:13:36 pm »
should be the other way around and use 1/4" plexi glass so 3/4" t-molding would be perfect.
OR use 5/8"+1/8" plexi and 3/4" t-molding for the top and 3/4" sides(thats what I have).
Meh...I got REALLY exicited about the cab.Couldnt wait to play.Now I added 3 shelves in there for all the consoles and the computer.
« Last Edit: November 11, 2003, 10:16:27 pm by SNAAAKE »
Cisco Kid
« Reply #7 on: November 11, 2003, 10:55:45 pm »
hehe ... mine is build like a brick sh*t house according to you guys  ;D
3/4" plywood with lots and lots of 2x4 bracing  :o (ok ... only 10 .... counting the 2 for the monitor mounts and the bottom panel for the casters to bolt into ... do those count ... lol)
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #8 on: November 11, 2003, 11:11:10 pm »
Did you ran a steel beam under the monitor, just for extra support.
This opinion was created from 100% post consumed information.
TalkingOctopus
  • Last login:July 16, 2024, 06:54:08 am
    • My Arcade
« Reply #9 on: November 11, 2003, 11:16:25 pm »
I used 5/8" MDF w/ my Happ over/under coindoor and it worked fine.
http://webpages.charter.net/rbecker5/images/insideJunk.jpg
eightbit
« Reply #10 on: November 12, 2003, 10:18:45 am »
Yet another cabinet that got sidetracked by play testing....  ;)
MonitorGuru
« Reply #11 on: November 12, 2003, 04:16:56 pm »
Unless you are building a interior frame out of 2x2's (or 2x4's), use 3/4" MDF for the two biggest side panels. It then is safe to use 1/2" MDF for cross pieces (since they dont span as great of an area.. 18 to 24" instead of 28 to 32"
I've built a mini out of 3/4" real oak laminated MDF for the sides then used 1x1's  stapled in the corners to support cross pieces of 1/2" MDF. I also routered out channels to put the cross pieces in.  It is so solid that i believe it could support a full size cabinet sitting on top of it safely.  Not a single 'creak' when moving it around, unlike the 'professional' built original cabinets.
Oh yeah, I also sealed all the seams with polyurathane plywood caulk glue (not the same as Gorilla glue, as this doesn't need water to activate)
