Author Topic: Arcade monitor to computer?  (Read 2464 times)
darkSSide
  • Last login:March 24, 2024, 08:19:48 pm
  • I want to make my own money!
« on: May 03, 2013, 12:33:37 pm »
How can I get my SI 727R-DS monitor to work with my computer?
darkSSide
Re: Arcade monitor to computer?
« Reply #1 on: May 03, 2013, 05:13:09 pm »
Would it be that simple just to get one of those Pc to Jamma conversion board?
Or do I really need to shell out some $$ for a VGA card and amp board connector?
Thoughts? Experiences with either way?
Sent from my Atari 2600
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 06, 2013, 12:43:07 am »
Bottom line is there are two options:
1) Get an ArcadeVGA and breakout cable from ultimarc.com (simplest, but more expensive)
2) Use a tool such as CRT_Emu_Driver or Soft15khz  (and a supported video card) to get low resolutions and hack your own VGA cable and connect it up. (cheap but you need to be comfortable with software configuration and hacking a cable).
sandheaver
« Reply #3 on: May 06, 2013, 10:47:47 am »
As a veteran of ArcadeVGAs and j-Pacs, I would recommend them highly.
They are indeed the more expensive solution, and you'll need to tweak MAME a bit for some games, but for ease it is the best solution and you get proper arcade modes.
If you're a person that is comfy cutting and splicing cables, and dorking around with drivers then the soft15khz solution would be what you'd want.
darkSSide
« Reply #4 on: May 06, 2013, 12:32:20 pm »
Looks like I'll eventually pick up the Arcade card. Now my question is do I need the J-pac or just the breakout amp cable with that vid card?
darkSSide
« Reply #5 on: May 06, 2013, 04:00:11 pm »
By the way I just want the monitor to work with my PC since I have a CP with an ipac.
sandheaver
« Reply #6 on: May 06, 2013, 06:42:22 pm »
Then any video card will do.  The ArcadeVGA & j-pac are for connecting a PC to an existing JAMMA cabinet w/arcade monitor.  If you're just connecting to a PC monitor from a PC then you need nothing special.
darkSSide
Re: Re: Arcade monitor to computer?
« Reply #7 on: May 06, 2013, 06:49:42 pm »
I should have clarified I want my Arcade monitor to work with my PC.
So let me start over I have an arcade monitor an old Dell PC and a Classic SLIKSTICK control panel with an ipac. I just want to hook up the arcade monitor to the PC.
So what would I need to do this?
sandheaver
« Reply #8 on: May 06, 2013, 07:27:26 pm »
Ah, sorry; ArcadeVGA & custom cable, then, if the arcade monitor has a connector like this: http://www.waste.org/~winkles/winterMAME/pix/videoConnector.jpg
The cable is easily made if you have a multimeter or continuity tester.  I believe there's a guy somewhere on this board selling them for $2 or something.
darkSSide
Re: Re: Re: Arcade monitor to computer?
« Reply #9 on: May 06, 2013, 08:25:11 pm »
SNAPS! I was hoping you would say that all I need was a vga adapter cable. Oh well probably best anyways to get the ArcadeVGA card.
Anybody know who is selling that cable/wire?
sandheaver
« Reply #10 on: May 06, 2013, 08:30:44 pm »
Well, you CAN if you use Soft15khz with a supported card, but I don't know what card you have now or if it is supported.  I tried 3 cards in two PCs and none of them worked with soft15khz.
I do have experience with ArcadeVGA and it just works.  Once in a while you'll come across a game that clearly isn't using the proper video mode, but a quick MAME config edit always fixed it.
darkSSide
« Reply #11 on: May 06, 2013, 08:51:59 pm »
sandheaver THANX for the info. Know I know who to ask when it comes to the ArcadeVGA card;)
