Author Topic: Hantarex Polo/2 28 Star Black Line  (Read 2498 times)
cloaknite
  • Last login:October 16, 2015, 12:31:06 pm
« on: April 30, 2013, 01:24:15 pm »
Hi there people! I have an hantarex polo/2 star crt monitor but it has some problems, a black vertical line on the left of the screen. The width of the line changes with the resolution, when I choose a resolution like 640x480 the line becomes slim and if I use a lower resolution like 320x240 the line gets bigger and more lines appear.
I showed the problem to a technician and he told me that if I change the contrast and the brightness the lines will go away, I tried to change that and the lines got lighter but when i change to a lower resolution the lines get darker again, can someone help me with this?
Thanks a lot!
Here are some photos:
https://www.dropbox.com/s/rcjv2q363fa3swa/IMAG1307.jpg
https://www.dropbox.com/s/4nyxx97j7gw6o3d/IMAG1342.jpg
https://www.dropbox.com/s/26boc8qxglfzwl3/IMAG1351.jpg
https://www.dropbox.com/s/oebc8x35uojdltj/IMAG1366.jpg
https://www.dropbox.com/sh/ko9o5uelwqda25g/CwU2a9eKHq#f:IMAG1299.jpg
https://www.dropbox.com/s/irlebcgdvp7mjbf/IMAG1301.jpg
https://www.dropbox.com/s/g04hf9vip8npcbq/IMAG1306.jpg
https://www.dropbox.com/s/a2lffi07pa62utf/2013-04-29%2020.59.01.jpg
grantspain
Re: Hantarex Polo/2 28 Star Black Line
« Reply #1 on: April 30, 2013, 04:06:32 pm »
check r36 270ohm on neck card
cloaknite
« Reply #2 on: May 01, 2013, 07:58:11 am »
Hi, here are the photos of r36 and r37, I have to replace them?
grantspain
« Reply #3 on: May 01, 2013, 11:29:57 am »
yeah sort of,when i say check i mean unsolder one side of the resistor and check with a multimeter it reads correctly
just replace r36 anyway
cloaknite
« Reply #4 on: May 02, 2013, 06:17:11 pm »
Hi again! I replaced the r36 and nothing happened, the black line is there :(
grantspain
« Reply #5 on: May 02, 2013, 08:04:39 pm »
has it had a replacement flyback transformer recently?
I had a new flyback from a supplier recently that caused a similar issue,changed for a different one and the problem went away
other problems could be electrolitic capacitors
normally that issue is down to r36
is this a polo 2 or a polostar monitor?
cloaknite
« Reply #6 on: May 02, 2013, 08:17:29 pm »
The flyback is the original one, the chassis says polo 2 star.
there is something else that I need to replace?
thanks a lot!
grantspain
« Reply #7 on: May 03, 2013, 07:53:14 pm »
you could try changing the 250v caps at c106,c109, and any on the output of the transformer in power supply section
