Author Topic: Copy of Little Ms. Pac-Man  (Read 37213 times)
Sshado
  • Last login:October 04, 2024, 06:10:57 pm
  • Sshado's Club
    • Sshado's Club
Re: Copy of Little Ms. Pac-Man
« Reply #80 on: May 14, 2013, 08:40:43 am »
I cut my plastics with a router, just set up a straight edge clamped down tight and run the router across it for a perfect smooth cut. If you want the edges of the acrylic to be glassy you can flame-polish them with a butane torch, look that up on YouTube for some videos showing you how.
Wow, the router sure cleaned it up nicely. Just like you, I am realizing the router is a VERY useful tool  :afro:
OK, another question for you. How did you attach the bottom? It must be fastened somehow if you are using handles to carry it from the bottom. I was thinking of putting a couple cross bars across and bolting the bottom to it through the feet...
« Last Edit: May 14, 2013, 08:44:09 am by Sshado »
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
Re: Re: Copy of Little Ms. Pac-Man
« Reply #81 on: May 14, 2013, 11:52:22 am »
Cool glad the router worked out. I screwed the bottom to the interior frame with brass screws, they look nice against the black laminate
mcseforsale
  • Creepy Mario Dude
« Reply #83 on: May 14, 2013, 06:11:11 pm »
/furiously scribbles a note to himself to pick up finishing washers on the way home.....
CoryBee
  • Bopity Boopy
« Reply #84 on: May 14, 2013, 07:17:09 pm »
To finish it off, I have sent Corybee a message about the serial plate.
1 - instead of where it says Griffin Dodd & Co., Ltd.
      change it to:
      Designed by Griffin Dodd
      Built by Weizguy
2 - SERIAL NO. WEI-00001
How is this?
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #85 on: May 15, 2013, 08:58:46 am »
How is this?
I can't view photobucket images from work :( I either need you to upload it or I will have to remember to look at it when I get home.
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #86 on: May 15, 2013, 09:02:21 am »
Nevermind, I looked at it on my phone, looks awesome!!
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #87 on: May 15, 2013, 10:23:45 am »
Couple more questions to complete this build:
How did you wire the speakers to the amplifier? I had the speakers connected to the 60n1 card, but now I want to add the amplifier.
Also, how or where do you wire the service / test buttons?
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #88 on: May 16, 2013, 11:33:55 am »
Was hoping to finish this weekend since Monday will be the 1 month mark, but I am still waiting for parts to arrive. Here is a shot of the custom feet I ordered from TEFightstands:
Maximus
    • Arcade Icons
« Reply #89 on: May 16, 2013, 11:40:49 am »
The amp I bought from amazon just had wire terminals so I attached them easily like that... I think, hard to remember now. The service buttons are part of that Jamma Harness, one called test and one called setup.
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #90 on: May 16, 2013, 12:26:00 pm »
Hmmm, I looked at your Jamma wiring map and it doesn't snow anything for test or setup. I also looked at the board and don't see a direct connect:
Maximus
    • Arcade Icons
« Reply #91 on: May 16, 2013, 12:27:52 pm »
Hrmmm, they are usually on the harness, do you have any wires at 8,9, or 11 or J,K,M on your harness?
« Reply #92 on: May 16, 2013, 12:29:13 pm »
Maximus
    • Arcade Icons
« Reply #93 on: May 16, 2013, 12:35:13 pm »
There you go, 15 parts side is the switch line for 'test' and 14 solder side is the switch line for 'service', just ground the other side of the switches and they will work
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #94 on: May 20, 2013, 09:07:50 am »
Quick update of the control panel, here is an image of gluing the T-molding and clamping down on the ends (sorry for poor picture quality):
Maximus
    • Arcade Icons
« Reply #95 on: May 20, 2013, 09:22:49 am »
Looking good man!
Jigenjuke
« Reply #96 on: May 20, 2013, 07:26:21 pm »
Looking good man!
What he said!
Jigenjuke
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #97 on: May 22, 2013, 08:56:16 am »
Thanks guys :) Hoping to get this finished this week, just waiting for some supplies to show up. Been working on my miniature (4 foot) arcade that I started 10 years ago and never finished in the meantime (miniature version of my first arcade).
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #98 on: May 25, 2013, 12:10:18 am »
Quick update, control panels are done and just finished the base. For the base, added the service and test buttons, added the handles, and added the custom pink feet (they will also have pink LED's). Just missing the serial plate (hint, hint Corybee)  ;)
Also been finishing up my mini arcade, it is 4 feet tall. Just waiting for my marquee and coin door so I can finish it up:
Maximus
    • Arcade Icons
« Reply #99 on: May 25, 2013, 02:56:59 pm »
Love those feet, way nicer than mine.
This may be a little late but I've attached a PDF with a bunch of JAMMA labels that you can print out and stick either side of the plug to make it much easier to identify the pins. Not mine, I found it over on KLOV
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #100 on: May 26, 2013, 12:17:44 am »
Thanks, I bought some of the "deluxe" wiring harnesses and they are similar.
Strange thing about them is that they have tilt wired up and not coin 2 - I had to change it.
Anyway, those will come in handy for my future projects :)
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #101 on: May 31, 2013, 03:46:39 pm »
I gotta say that this build is a ---smurfette---!! Maximus made it look easy. There are so many little tweaks here and there that need to be considered while building it. I am planning on finishing this up this weekend and will have a couple of pictures.
It is such a pain in the ass that I can't wait to be done...   :dizzy:
Maximus
    • Arcade Icons
« Reply #102 on: May 31, 2013, 03:58:51 pm »
Lol, I must admit it is a very tightly packed unit, there's a lot going on under the hood, but when you finish it you'll have a blast playing it, and I'm sure your friends will too.
Can't wait to see your pics (and a video???).
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #103 on: June 01, 2013, 04:38:53 pm »
A couple of issues :( I hooked up the speakers to the amp and I am getting a humming noise? I also do not have the pink dustwashers in due to them being see through and can see my misaligned joystick holes, but I do have the pink LEDs in there...
Also, I am going to have to replace the bezel as I ---fouled up beyond all recognition--- it up   :badmood:
Here are a couple of pictures of how it sits currently. The glowing feet look cool from the bottom, can't see it in the carpet, but you can see a glow on solid floors. I also still have to connect the button LED's.
« Last Edit: June 01, 2013, 04:42:09 pm by Sshado »
Maximus
    • Arcade Icons
« Reply #104 on: June 01, 2013, 05:35:21 pm »
Nice man I think it looks fanstastic!! The glowing feet are a nice touch. WIth the speakers and amp, make sure you dont have the speaker wires running directly next to power wires, that's probably where your hum is coming from, also crank up the volume in the game settings on the 60-in-1 board so you dont have to turn the amp up as high, this will also eliminate ground hum.
Looks like you are almost done, it's weird seeing a clone of mine looking so complete, but a huge compliment that someone else liked it enough to go through the expense and trouble to make one.
Congrats!!
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #105 on: June 04, 2013, 09:08:38 am »
Thanks, this build is now complete and here is a final shot (not the best quality photo):
Maximus
    • Arcade Icons
« Reply #106 on: June 04, 2013, 09:20:10 am »
That's awsome now the question is have you had a baby sit on the screen to test build quality?
dgame
  • I am no Jedi
« Reply #107 on: June 04, 2013, 09:38:04 am »
cute
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #108 on: June 04, 2013, 09:40:20 am »
I could test it with my 25 lb cat ;)
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #109 on: June 04, 2013, 10:16:00 am »
I like it, quite unique.
mcseforsale
  • Creepy Mario Dude
« Reply #110 on: June 04, 2013, 12:25:54 pm »
Maximus
    • Arcade Icons
« Reply #111 on: June 04, 2013, 12:30:10 pm »
Videos of that please, the Internetz needs more videos of fat cats playing arcade games.
« Reply #112 on: June 04, 2013, 12:42:54 pm »
CoryBee
  • Bopity Boopy
« Reply #113 on: June 04, 2013, 04:17:47 pm »
Did you receive the serial plates?
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #114 on: June 04, 2013, 04:27:28 pm »
Yes, thank you, I had a little problem with the screws stripping, so I ended up using some finishing nails. I took a picture last night, but it turned out too dark, I will take one tonight and post a final pic.
Maybe I will try to make a video of it tonight, although I have never done a video before.
>:D
My thought exactly.
I get it  ;)
CoryBee
  • Bopity Boopy
« Reply #115 on: June 04, 2013, 05:07:13 pm »
The build looks great by the way.
Yes please pictures of the plate installed and of the tiny plate next to it.  :applaud:
No build the revolution cab!  >:D
Maximus
    • Arcade Icons
« Reply #116 on: June 04, 2013, 05:13:20 pm »
Now build the revolution cab!  >:D
Lol. Or buy a barrel.
  • Last login:Today at 09:10:05 am
« Reply #117 on: June 04, 2013, 06:12:56 pm »
* Insert obligatory joke about it being someone's turn in the barrel.   >:D
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #118 on: October 13, 2014, 08:23:50 pm »
Whelp... I bought a barrel and will be starting a barrel cocktail cab for a wine club :)
  • Last login:February 23, 2026, 02:55:37 pm
« Reply #119 on: October 19, 2014, 08:01:02 am »
Result! :cheers:
