Author Topic: What size Mini-Pac Connectors do I need? 6.3mm, 4.7mm, 4.8mm or 4.8-2.8mm?  (Read 4262 times)
rs207200
  • Last login:June 24, 2013, 03:18:31 pm
First off, I've been using this forum for a long time and it's been a huge assistance.  And I know I'm breaking a cardinal rule by posting a question that has probably been answered many times, but my searches failed me.  The Mini-Pac comes with 4 connector sizes:
Which connector size do I need?  I'll be using Happ Push Buttons and Happ 8-Way Competition Joysticks.
*Bonus question 1: Does an 8-way joystick use up 8 inputs on the Mini-Pac?
**Bonus question 2: If I were to buy illuminated buttons, what size connectors do I need?
Thanks in advance! :burgerking:
happyfunball
  • Last login:December 11, 2015, 07:49:39 pm
do you already have the joysticks or the buttons? if so you can measure the connectors.
if you can't find that info or nobody here can provide it, i'd order the joysticks and buttons first, measure them, then order the harness that fits.
I have several min-pacs and everything I've connected them to has been 4.7 except for some of ultimarc's buttons which are smaller.
  • Last login:Today at 05:20:40 pm
Commonly used crimp sizes include:
6.3mm / .250" - Not used too often, but some microswitches have straight .250" tabs and some use a stepped design (shown) that can work with .187" or .250" if you seat it fully.
4.8mm / .187" - The most common size for American/European sticks/buttons.
2.8mm / .110" - Mostly used on older leaf switches/joysticks and Japanese buttons.
Normally my snap answer would be .187", but I got a batch of Happ buttons from Andy a while back that had .250" straight tabs. (Used them for the build in my sig)
Next button (+ Mini-Pac w. 4.8mm harness) order from Andy had stepped side .187"/.250" tabs.  :dunno
Nope, only 4.  You get 8-way by closing 2 switches at once. (Up+Right, etc.)
For this type, use .250" for the two downward-pointing LED connections and .187" for the microswitch.
