Author Topic: 11/16 T-molding - Red (In Stock) Cheap - .40/ft No Minimum - Flat Rate Ship  (Read 2464 times)
rablack97
I have the red in stock for those interested......
Looks really good with the laminate....
« Last Edit: April 26, 2013, 07:49:13 pm by rablack97 »
Re: 11/16 T-molding - Interest Check - For Laminate Builds
« Reply #1 on: April 17, 2013, 03:03:21 pm »
You can get black and white 11/16" t-molding in 20ft coils from t-molding.com.
http://www.t-molding.com/store/home.php?cat=23
rablack97
« Reply #2 on: April 17, 2013, 03:31:59 pm »
Its the red blue and green i'm really looking at.
« Reply #3 on: April 17, 2013, 03:38:07 pm »
Your OP lists black, no green...
rablack97
« Reply #4 on: April 17, 2013, 04:15:30 pm »
I know, you can't get red, blue, green anywhere in this width w/o buying a huge spool of it.
I added black cause if its cheaper to buy it in a spool and the response was decent, i would look into that too.
T-molding.com is the only spot you can source it, but folks might want different colors including black and can get it cheaper together and not get raped on the shipping.
rablack97
ok folks,
I pulled the trigger, needed the stuff for my builds.....
If anyone wants some, send me a PM.
I wanted to offer this stuff to folks who didnt want to get the whole spool.  I'll get what i can in the flat rate boxes.
Best to do at least 10ft, to make it worth your while.
rablack97
nanoflower
  • Last login:February 15, 2025, 08:43:21 am
  • All Your Base Are Belong To Us
Hi
So you have any left, and where did you buy it from originally?
/nano
rablack97
Yep sure do.
You can't but this stuff in short stock, i ordered it from a plastics manuf in a 250 ft roll, which is the minimum.
If you need some i still have some left over, it will save you from having to buy a 250 ft roll, i have it in blue too.  Let me know how much and your zip and i'll send you a quote.
nanoflower
Yep sure do.
Hi, thank you for the reply. I haven't decided on a color scheme yet but it's nice not having to be restricted to black or white. At this point I've gathered all the electronic parts and I'm currently stocking up on tools and other mechanical stuff and if the plan sticks I will begin my build this summer.
I will get back to you when time come should I decide to go red or blue if that is OK?
/nanoflower
