Author Topic: Push button PC power on. PLEASE RESPOND!!!!!  (Read 10288 times)
Jeromebechaz
  • Last login:April 05, 2017, 06:16:20 am
« on: April 14, 2013, 10:29:55 pm »
I might sound like a noob but I just cannot find  the answer anywhere. I just want to know how to power on a PC with a push button. I know a little bit of general knowledge on computers. But no idea how to do this.
Please reply
Zeenon
  • Last login:January 26, 2018, 08:51:10 pm
  • New Jersey - The Greatest Country in the World
Re: Push button PC power on. PLEASE RESPOND!!!!!
« Reply #1 on: April 14, 2013, 10:45:40 pm »
On most motherboards there is a header on the motherboard labeled PWR SW. It is usually grouped with a bank of pins on one corner of the board...PWR LED, RESET, HD LED, PWR SW, SPEAKER.
For my cab I created a 'Y' cable. One end went to the original power switch the other went to a push button on top of the cab.....both of those connected to the motherboard like the picture above. So I can either use the power button on the PC like normal or a push button on top of the cab.
If you just want to power the PC with a push button buy one of these:
Wire one slot to Common and the other to N/O (Normally Open) and attach to your motherboard in the place of the old power sw. I think radio shack sells the header and pins in one package.
Z
« Last Edit: April 14, 2013, 10:50:14 pm by Zeenon »
Jeromebechaz
« Reply #2 on: April 14, 2013, 11:51:04 pm »
thanks heaps!!!
that makes tots of sense, plus i dont have to destroy and existing wires haha
Zeenon
« Reply #3 on: April 15, 2013, 09:33:02 am »
Bring this to radio shack and show/tell them what you are trying to do:
You need to make two of these:
Label each one, #1 and #2.
Once you have those made, the left side connector in the above pic goes into one of these:
This end will goto the motherboard.
Now you should have 4 wires, take one from #1 and one from #2 and push them into one of these again:
This will goto the old PWR SW that was connected to the motherboard.
Do the same with the other #1 and #2 wires and connect this to your push button.
Z
ahofle
    • Arcade Ambience Project
« Reply #4 on: April 15, 2013, 09:41:41 am »
Even easier:
http://www.amazon.com/HDE-Power-Motherboard-Switch-Button/dp/B00345WH4A
Snip the ends near the switch and wire to a button (or just use the button in the picture).
ark_ader
  • I glow in the dark.
« Reply #5 on: April 15, 2013, 11:45:31 am »
Even easier still:
http://compare.ebay.co.uk/like/190807921779?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
http://www.amazon.com/Sub-Mini-Push-Button-Momentary-Switch/dp/B004GIKRNC
Plug the end of the switch into the other side of the connector and secure it to the case via a screw hole.
A bit tight but it fits.  ;D
Works great.
