Author Topic: both sticks for gamelist control?  (Read 3583 times)
Luigi
  • Collecting/restoring cabs
« on: April 12, 2013, 12:34:42 am »
Hi.
Is it possible to use both joysticks to control the Mala gamelist?
« Last Edit: April 12, 2013, 01:27:38 am by Luigi »
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
Re: both sticks for gamelist control?
« Reply #1 on: April 15, 2013, 05:54:42 pm »
Not that I know of since the Mala controls panel only accepts one key input per movement. It might be possible however using Auto Hot Key as a separately running program to remap additional keys. Problem is this, this will likely mess up the game functions later on unless you can somehow get that AHK file to close before Mala launches a game.... probably not worth it in my opinion. :)
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
Luigi
« Reply #2 on: April 16, 2013, 02:22:21 am »
You're right with everything you say. I hoped there would be a workaround for the 'one key only' but using Auto Hot Key would not be the solution. :)
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #3 on: April 28, 2013, 12:41:53 am »
dont know if it`d work as i dont know how many similtaneous inputs can be triggered at the same time but if you have two spare inputs you could wire them to both the up and down of both player joysticks (so they both trigger the two extras plus their intended inputs at the same time) and set mala to recognise the two extra inputs that would do nothing except move the game list?
--- forget that just thought it through wouldnt work, how about two separate inputs within reach of both players, or specific game selection either side :)
« Last Edit: April 28, 2013, 12:59:19 am by CpCaveman »
Hit something hard enough it should work, if it dont the result can always be called art :)
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #4 on: April 28, 2013, 02:59:02 am »
authotkey should work as long as you specify that the "same button" triggers are only active when the mala window is active
« Reply #5 on: April 28, 2013, 07:20:40 pm »
maybe it's because I use a gamepad style interface but I have both of my joysticks with gameslist control.
