Author Topic: Makvision 2929D Ati 4550 issues  (Read 3580 times)
emusnes
  • Last login:April 04, 2013, 05:29:20 pm
« on: April 04, 2013, 04:45:27 pm »
I cannot get my ATI card to output any video to the Makvision monitor.  The monitor only displays the "Disconnect" message which means nothing is plugged in.  If I use my two other nvidia cards the monitor works fine.  Here are some details below.  Not even the bios screen will display while using the ATI card.
Ati 4550 (VGA and DVI on the back)
Windows XP x64
Calamity drivers
I would like to use the ATI card to get the benefits from GM if possible.
I am currently using the VGA port on the card instead of DVI to VGA.  I have tried three dvi to vga adapters and no video will come out even on my lcd monitor.  Using the built in VGA port my LCD monitor does work.  I have tried 800x600 60hz with no luck.  When using the nvidia card the bios screen shows on the 2929d and windows loads fine.
Any thoughts?
-Josh
