Author Topic: what prog do i use to read/edit .cfg files?!?  (Read 3358 times)
jammadave
  • Last login:August 30, 2005, 04:07:28 pm
  • cats$ chown -R us:us yourbase/
    • Jammadave's Home on the Web
« on: April 02, 2002, 08:04:26 pm »
subject line sez it all =0)  need to fiddle with some cfg files for project:starwars.
project:SW has landed, played it in my gameroom tonight, once the rom is running it's perfection but currently running mame32 with no frontend, must remedy this situation if i want it to menu between SW and ESB.
Jammadave - Arcade collector.
Current Collection:  MsPac, Asteroids, Joust, KickMan, Hydra, Warlords (cocktail), plus Fish Tales & Creature from the Black Lagoon (pinballs)
JustMichael
  • Mmmmm!! Cheesecake!!
Re: what prog do i use to read/edit .cfg files?!?
« Reply #1 on: April 02, 2002, 09:24:19 pm »
Have you tried Edit or Notepad?
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
« Reply #2 on: April 02, 2002, 09:44:58 pm »
Heh, have you?  mame's .cfg files (which he's obviously talking about) aren't readable with a text editor like notepad or edit.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Best to use mame. :|
« Reply #3 on: April 03, 2002, 08:43:16 pm »
The .cfg files are not a standard size or format.  You can look at them with a hex editor, but each game pretty much has it's own layout.  The layout depends on the type of input (joystick/spinner/trackball/analog joystick) used, the # of joysticks/spinners/trackballs in the game, the # of buttons, # of players, and order they are listed in the game's driver.
I think all the starwars games have the same .cfg file layout (same driver?), but different than StreetFighterII (different type of joystick, different # joysticks, different # buttons, different # of players).  Since you are interested in one game's .cfg file, you can: make one change in mame, copy and rename the .cfg file, and compare in a hex editor.  Repeat.  Time consuming, I know:  was doing that myself with SuperSprint a while ago.  (used textPad's hex reader, but there's much better hex editors out there I'm sure.)
Robin
Knowledge is Power
jammadave
« Reply #4 on: April 04, 2002, 04:44:26 am »
however, in this case i'm actually talking about mame.cfg, glaunch.cfg, et cetera.  not the game configs themselves =0)
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
« Reply #5 on: April 07, 2002, 12:04:52 am »
then in that case just use notepad or wordpad
Jakobud
