Author Topic: Wiring limit switch to pololu 18v7  (Read 5457 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: March 31, 2013, 05:09:07 am »
While I'm waiting for my motor to be delivered I thought I'd research how to connect the switches, motor and pololu 18v7 up.
On the following Web page at the bottom, which diagram should I follow, left or right?
http://www.pololu.com/docs/0J44/4.4
With regard to electronics I can just about wire a plug so please do advise on anything else that I need to do.
Midlife
  • Last login:April 13, 2013, 02:49:29 am
Re: Wiring limit switch to pololu 18v7
« Reply #1 on: April 01, 2013, 05:24:46 pm »
Follow the diagram on the left.
One switch will connect to Analog input channel 1 and Pot - and the other to Analog input channel 2 and Pot -.
Connorsdad
« Reply #2 on: April 01, 2013, 06:16:45 pm »
Thank you :)
