Author Topic: ArcadeVGA configuration issue - unknown Wells-Gardner monitor  (Read 2479 times)
NineInchNall
  • Last login:March 31, 2013, 09:23:58 pm
Okay, so I'm attempting to resurrect a system (that someone else built) in which the original mobo went bzzzzzt. The system originally used an AGP ArcadeVGA, but since that specification no longer really exists, I bought a shiny new ArcadeVGA 3000 and shiny new mobo, proc, and all the rest. Okay, so here's where the difficulty comes in:
I don't know how to configure the AVGA/JPAC combo to work with the monitor. It's a 33" Wells-Gardner monitor, one which I know for a fact can handle low res (eg., 256x256) and higher res (eg., 800x600). Yes, I said 800x600. Anyway, it's not a D9200, since that has a nice VGA port on the back and a convenient OSD for adjusting stuff. No, I'd have to adjust some potentiometers in back to change anything not on the remote PCB (which handles brightness, contrast, h size, h pos, v size, & v pos).
I tried looking on the WG site, but the only 33" monitor listed there is the D9200 - which, again, this doesn't appear to be. I also tried using their Serial# lookup, but apparently, my unit's a secret agent.
WGM3330-U0TS39K
054A0756-001
P789
P756
With the JPAC's 15 and 31 kHz jumpers set, the best I can get through the AVGA card is a divided image (as in the first attachment). No other jumper configuration seems to work. Like, at all. The funny thing is that the LCD monitor I have hooked to the DVI port works flawlessly, displaying all the wonderful low resolutions I bought the card for.
Oddly, however, I can get a rather nice picture out of Soft15 and an old Radeon HD4800 I had lying around. With the JPAC's jumpers on 15 and 31 or just on 15, 640x480 shines through all pretty like. 800x600 displays, but it can't get v-sync, so it just rolls and rolls and rolls. And that through a DVI-VGA adapter, no less. I'd make do with that, but Soft15 doesn't give as many res options as the AVGA card does, and were it not for the fact that I know this screen can display 800x600.
So I come to you, oh wise and learned members of this forum. What am I doing wrong with the AVGA that is preventing it from sending the proper signal to the arcade monitor? I mean, it doesn't appear to be a JPAC issue, since the display works fine with Soft15.
Halp!  :dizzy:
« Last Edit: March 30, 2013, 07:39:40 pm by NineInchNall »
lilshawn
  • Last login:February 03, 2026, 06:10:43 pm
Re: ArcadeVGA configuration issue - unknown Wells-Gardner monitor
« Reply #1 on: March 31, 2013, 09:16:35 pm »
it's a U3000/K7600. there wasn't many machines that used it. (Ultimate Mortal Kombat and Primal Rage) which is why you aren't going to find any real info on it.
it's still a 15k monitor. You aren't going to get much resolution out of it. it definitely wont do 800x600 without some kind of video card mumbo jumbo scan conversion or a hardware scan converter. (least that's what I think. i don't know how you know it does 800x600)
check out http://www.ultimarc.com/ site or give Andy a PM and see if he can get you configured.
NineInchNall
« Reply #2 on: March 31, 2013, 09:23:58 pm »
Thanks for the ID help. I'll see if Andy can help.
mamenewb100
  • Last login:April 01, 2022, 03:32:29 pm
« Reply #3 on: March 31, 2013, 11:59:09 pm »
Actually it MIGHT be possible to get close to 800x600 interlaced on a 15K monitor with a low refresh like 50 Hertz. Of course this also depends on how narrow the horizontal frequency range of your monitor is. I know most can't go much above 640x480i though. This would be worthless for games but ok for a desktop.
« Last Edit: April 01, 2013, 12:55:22 am by mamenewb100 »
Life is a Game and we are all being Played.
MTPPC
« Reply #4 on: April 03, 2013, 10:28:29 pm »
When you have the jpac's 15khz jumper set, any resolution over 15khz will be halved. I don't think you are supposed to have both 15 and 31khz jumpers at the same time.
http://pinballmd.com/
