Author Topic: PS2 AND DC  (Read 6425 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
PS2 AND DC
« on: November 08, 2003, 08:50:11 pm »
I know there has been a lot of talk on the threads about connecting a dc to your control panel, but could connect your ps2, dc, and pc all to the same set of controls? I have no skills at this stuff so it's more of a question of curiosity.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:PS2 AND DC
« Reply #1 on: November 09, 2003, 12:50:06 am »
I wouldn't see why not .  If you want them all hooked up at the same time, I'm sure the diode method would work for the P-S2 as well as the DC.
I just have the DC and PC hooked up but the diode method works flawlessly.
SNAAAKE
  • -Banned-
Re:PS2 AND DC
« Reply #2 on: November 09, 2003, 02:28:34 am »
Converter would be easier.
IF you do diode method then I-pac for pc then  2 ps hacked pad for ps2 and 2 others for dc.
now converter would be a lot easier.
just hack 2 ps pads and use for ps2,dreamcast using converter,and pc using converter as well.
This is the "easier" solution imo. :)
« Last Edit: November 09, 2003, 03:24:30 am by SNAAAKE »
Shieldwolf
  • SpearShield.com
Re:PS2 AND DC
« Reply #3 on: November 09, 2003, 01:55:33 pm »
Two things:
1 I'm usigg a hangstrom encoder not an ipac, but that shouldn't really matter.
2 Could you explain the converter a little more snake.
jr76
  • Last login:August 13, 2007, 10:44:53 am
  • Must...stop...planning
Re:PS2 AND DC
« Reply #4 on: November 18, 2003, 01:05:39 pm »
I'm currently building a panel to use with Dreamcast/PS2/Xbox.
I'm basing it on these plans
http://mywebpages.comcast.net/jdpyle1/arcade_sticks.htm but am changing a few things. Instead of using different project boxes for each console, I'm using a parallel printing switch for each player. They are four-way switches so once I complete this, players will be able to select Dreamcast/PS2/Xbox/Mame. I don't think I'll have to worry about diodes with this setup.
Shieldwolf
  • SpearShield.com
Re:PS2 AND DC
« Reply #5 on: November 19, 2003, 02:08:47 pm »
JR76,
that sounds amazing!!!!
Can you send me pics and or directions for dummies?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:PS2 AND DC
« Reply #6 on: November 20, 2003, 01:29:16 am »
JR76,
I'd wait until he finishes it...others have had problems using switchboxes in this manner.  Hope he does succeed though.
jr76
Re:PS2 AND DC
« Reply #7 on: November 22, 2003, 04:00:31 pm »
If I get it to work, I will post pics and directions. I don't see what the problem would be though, from what I can tell the switcher box isn't anything but that, an unpowered switcher. It's just making a physical connection, the same as unplugging a 25 pin connector and plugging it into a different one. Am I wrong?
jr76
Re:PS2 AND DC
« Reply #8 on: November 24, 2003, 06:44:26 am »
Connecting to the parallel box should be no problem. I was out of town last week and all my parts I ordered came in so I was able to do a quick test this weekend.
I soldered up a dreamcast controller and connected the wires to the swticher. I used Printer cables and it didn't worked. I don't know why, but here is my theory.
When you strip open a parallel printer cable, there are about 20 stranded cables on the inside. I mapped out these wires to there respective pin by using a continuity tester. All the printer cables I striped had the same color scheme so I assumed that the wires would map to the same pin. I was wrong, this isn't the case! For example, I had on cable where the brown wire mapped to pin 5. On a bother cable, the brown wire mapped to pin 15.
So I wired up my on db25 connectors. I was in a hurry so I just did button A on the DC controller. I set up another db25 connector and hooked a button up to it. Connected the db25's to the switch box, put in a copy of Street Fighter X, and it worked! Ryu was kicking everytime I pushed the button.
Conclusion, if people were having problems with the parallel cable switchers, I don't think it was due to the switches, I think it was because of the cables! I will be soldering my own db25 connectors instead of mapping 8 different sets of printer cables!
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Re:PS2 AND DC
« Reply #9 on: December 09, 2003, 04:21:32 pm »
cool im glad youre making progress, im interested in doing this but im a newbie at this so hopefully you can make some easy directions or you would make them and sell em to me =)
"Owens is the ringleader in the ass hat circus"  D K
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
Re:PS2 AND DC
« Reply #10 on: December 13, 2003, 02:21:33 pm »
diodes the best just turn on the console or pc and you play no screwing with the connectors
Shieldwolf
  • SpearShield.com
Re:PS2 AND DC
« Reply #11 on: December 19, 2003, 12:06:34 pm »
so did it work?
jr76
Re:PS2 AND DC
« Reply #12 on: December 19, 2003, 01:03:05 pm »
My setup did and does work. I don't have any delay either. My control panel looks like junk, I plan on building a nicer one and documenting on how I did it. Once I do, I'll let everyone know.
I would be interested to see instructions on how to do the diode thing. While I'm using a selector, it would be cool to just turn a console on and go. However, what if you have two consoles on at the same time?
Shieldwolf
  • SpearShield.com
Re:PS2 AND DC
« Reply #13 on: January 09, 2004, 01:41:07 pm »
So what's the final verdict? Any chance we'll see some plans soon?
