Author Topic: FAO Howard or Badmouth  (Read 2739 times)
MartinJames
  • Last login:March 28, 2021, 10:10:33 am
« on: March 26, 2013, 07:17:29 pm »
Hi chaps. Could either of you help? Sega Model 2 emulator. All force feedback works on a G27 perfectly, but with my Fanatec crs wheels sega rally and indy 500 vibrate like mad. I can still feel the underlying feedback but it has massive uncentering or something vibrating away when you turn it.many ideas chaps.
I can tell you you cant dial it out with the ini setting unless you know someone I dont! Fyi im building a 4 player setup based on fanatec and happ gear.
Thanks.
MartinJames
Re: FAO Howard or Badmouth
« Reply #1 on: March 26, 2013, 07:18:28 pm »
To add : daytona works perfectly.
  • Last login:July 30, 2025, 06:08:43 pm
« Reply #2 on: March 26, 2013, 07:30:39 pm »
Sega Rally and Indy both have the "outrun style" FF.  By that I mean they fluctuate slightly left and right when the wheel is idle.  There really isn't much of a solution for it atm, but turning down the power of the FF should help a lot.
Just play with your settings until it smooths out a little.  They really should make a difference.  Understand that you have to completely exit model 2 and sometimes even unplug your wheel after changing the settings.
MartinJames
« Reply #3 on: March 27, 2013, 05:39:36 am »
Thanks, yes turning down teh FF to almost zero works, but kinda defeats the purpose.
Why does the G27 work fine and my Fanatec does not?
Martin
