Author Topic: Flyback for Wg k700  (Read 3840 times)
juanchocnva
  • Last login:October 23, 2013, 10:12:01 pm
Flyback for Wg k700
« on: March 26, 2013, 11:24:25 am »
Hello forum  ;D
Ok so  am ready to replace the flyback of my neo geo cab the picture its now very blurry and the colors tear when trying to adjust the brightness on the flyback
the chasis needs cap kit and flyback replacement since all the cap look pretty old and i want to keep this monitor running for some more years    :lol
so my problem is that most of the wg k700 use a flyback with only one anode cable going to the tube but my has two one going from the flyback to the tube and the other one from this thing to the tube
so my question is if i order the regular k700 series kit from bobroberts would this flayback replace my old one or i need one with two anode cables??
 :banghead: am a noob at this but everytime a watch a video on youtube on how to replace a k700 flyback they always have this single cable flyback
and what is that thing in they flyback any way?
Ken Layton
  • Guru
  • Technician
Re: Flyback for Wg k700
« Reply #1 on: March 26, 2013, 12:21:24 pm »
Your picture shows you have a Zenith made K7000A. The flyback for that model is completely different and no longer available anywhere.
You need to install new capacitors first anyway before doing anything else.
juanchocnva
« Reply #2 on: March 26, 2013, 03:04:15 pm »
thanks alot for your response :
 :badmood:
am a guy with bad luck
yeah am doing the cap kit but since am doing in i really would like to install that new flyback
so would you recommend me buying a new chasis?
what are my options  :dunno
juanchocnva
« Reply #3 on: March 26, 2013, 03:21:52 pm »
never mind
just quoting from other post
info on the zenith K7000A chassis as provided by Ken Layton:
Around 1990 or so Wells-Gardner was getting so many orders from game manufacturers that they were falling behind in production. The k7000 was their most popular model at the time for arcade video games. So they subcontracted with Zenith Electronics for Zenith to build the k7000 MAIN circuit board and NECK board (but not the remote adjustment board). This became known as the "K7000A" chassis. It did not have the usual "P447" or "P538" numbers silk screened on the circuit board like the genuine Wells-Gardners did. Instead the main board is silk screened 204-2205-07 and the neckboard is silk screened 204-2203-02.
The easiest way to identify this version is that there are TWO PINK wires going to the suction cup whereas the standard Wells-Gardner k7000 has ONE RED wire going to the suction cup. It is unfortunate that Zenith chose to partly redesign the circuit board from Wells-Gardner's design in order to use a proprietary Zenith made flyback. This particular flyback (Zenith numbers 95-4149 and A-15945) is no longer available anywhere thus making this chassis unrepairable should the flyback fail (a common problem). The flyback for standard Wells made k7000 (the 0528 flyback available from many suppliers) will not physically nor electrically work to repair the Zenith made chassis.
So if you have a k7000A chassis and the flyback is bad, then you're only hope to repair the monitor would be to either get a working regular k7000 Wells-made chassis (direct plug 'n play swap) or order an 8liners.com universal replacement chassis.
BTW, the k7000A uses the same cap kits as the regular Wells-Gardner K7000 monitors. Zenith kept the same component designations (and values) on the pc boards at least.
Oh, and to further confuse people, Wells used (mostly) Zenith picture tubes in both versions.
juanchocnva
« Reply #4 on: March 26, 2013, 03:24:45 pm »
what would be a good chasis to purchase ??
a real k700 series?
where should i be searching for it ebay?
how much is a good price to buy it  working and not working?
thanks for your response
 :notworthy:
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #5 on: June 13, 2013, 05:01:41 am »
i sell rebuilt K7000 chassis.
if you would like one contact me thru my site.
thearcadebuffett.com
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
