Author Topic: 1" plywood/mdf  (Read 2313 times)
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
1" plywood/mdf
« on: November 08, 2003, 02:31:12 pm »
Hey, I'm redoing the top of my Cocktail and I was wondering where you can buy 1" plywood or MDF.  None of the discount chains carry it.
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
shumph
  • Last login:December 23, 2003, 05:24:03 pm
Re:1" plywood/mdf
« Reply #1 on: November 08, 2003, 02:34:06 pm »
1 inch is usally special order
and is more expensive than laminating 2 pieces of 5/8 together
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
Re:1" plywood/mdf
« Reply #2 on: November 08, 2003, 03:23:55 pm »
My local Home Depot has 1" MDF. Do you really need to go that thick? I also say it is cheaper to laminate\glue to pieces together. Then again if you got the money it does save some work with just the one piece! So my advice would be to check your local Home Depot.
dhansen
    • Arcade Stupidity
Re:1" plywood/mdf
« Reply #3 on: November 08, 2003, 05:06:59 pm »
The original Pac cocktails had a 1" thick top, plus I bought new clips and t-molding to redo it.  I might just go the 2-5/8 route...my home depot doesn't have this size.
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
Re:1" plywood/mdf
« Reply #4 on: November 18, 2003, 06:42:50 pm »
perhaps this is a stupid question...but why wouldn't you glue two 1/2 sheets together to get 1"?
I though plywood thickness was actual size...
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
dhansen
    • Arcade Stupidity
Re:1" plywood/mdf
« Reply #5 on: November 18, 2003, 07:13:00 pm »
You have a point there... Plywood is always not as thick as advertised ???, however MDF is.  I'll take my t-molding down to the lumberyard and make sure I get the right stuff...
Doug
SirPeale
  • Green Mountain Man
Re:1" plywood/mdf
« Reply #6 on: November 19, 2003, 09:08:58 am »
You do mean 1/2, right?
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
Re:1" plywood/mdf
« Reply #7 on: November 19, 2003, 10:53:20 am »
 ???  Hey Peale, did you read the thread?
(Sorry, I had to give you a hard time. ;) )
SirPeale
Re:1" plywood/mdf
« Reply #8 on: November 19, 2003, 11:15:00 am »
I read it.  Just curious is all.  The thickness isn't usually far off when it comes to actual measurements, that I've seen in my limited woodworking skill.
SirPeale
Re:1" plywood/mdf
« Reply #9 on: November 19, 2003, 11:18:38 am »
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
Re:1" plywood/mdf
« Reply #10 on: November 19, 2003, 12:48:57 pm »
You could always glue pieces of wood around the sides to get you to your correct thickness.  This would save on material and weight.  Just a thought.
Jonathan
