Author Topic: Wireless options  (Read 1958 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
Wireless options
« on: March 20, 2013, 09:13:10 am »
Hello, is there any wireless options to turn on a PC?  I would like to be able to turn on my Mame Machines with a remote.  I think it would be a cool affect just like an arcade turning on.  I currently have my machines set up with a power switch and a button push (micro switch running to the power of the PC).  It would be nice to flip a master switch and then hit a remote button to turn them all on at once!
Any suggestions?
-SP
JDFan
Re: Wireless options
« Reply #1 on: March 20, 2013, 10:36:42 am »
They have remotes that plug into the wall outlet that should work for this for example this unit on Deal Extreme http://dx.com/p/wireless-remote-controlled-ac-power-adapter-set-110v-us-plug-59269 :
southpaw13
  • Whatever!
« Reply #2 on: March 20, 2013, 02:03:22 pm »
Yes, that's just for the power, how do you get a wireless signal to the PC to turn on????
-SP
« Reply #3 on: March 20, 2013, 02:19:19 pm »
You should be able to set your PC to turn on after a power loss.
  • Last login:December 19, 2025, 12:23:29 pm
« Reply #4 on: March 20, 2013, 02:22:11 pm »
-SP
Search for remote momentary relay on fleabay or amazon.
If everything other than the PC is run through a smart strip and the power button is triggered by the relay, it should work as you want.
Example:
http://www.amazon.com/Channel-Wireless-Control-Receiver-Momentary/dp/B00BQ842DG/ref=sr_1_10?ie=UTF8&qid=1363803485&sr=8-10&keywords=remote+momentary+relay
Disclaimer: I have not tried this.
southpaw13
  • Whatever!
« Reply #5 on: March 20, 2013, 05:59:38 pm »
I don't like the power loss thing because the computer will not be shut down properly to use it.  I found these on ebay and I am probably going with it.
http://www.ebay.com/itm/4CH-Wireless-Remote-control-Fixed-code-1CH-Receiver-Momentary-Toggle-Switch-/110777547901?pt=US_Lighting_Parts_and_Accessories&hash=item19cadb3c7d
Thanks for your help,
-SP
gtxjoe
  • Last login:August 19, 2022, 08:55:58 am
« Reply #6 on: March 20, 2013, 09:45:30 pm »
Google HTPC turn on with remote to get some ideas.
I have a Windows MCE remote and IR to USB adapter that I use to put the HTPC to sleep/standby and wake it up .    To turn it on from OFF or Hibernate state, I think you need to have a motherboard with CIR port.   Here is some info on CIR http://shop.inteset.com/Products/5-intel-cir-receiver.aspx
« Last Edit: March 20, 2013, 09:49:16 pm by gtxjoe »
southpaw13
  • Whatever!
« Reply #7 on: March 21, 2013, 07:56:59 pm »
Thanks-a little expensive.  I can get 4 cabinets working for $36.
Thanks,
-SP
