Author Topic: Does Ultimarc's video amplifier protect arcade monitors from 31kHz sync?  (Read 2234 times)
tobiasbp
  • Last login:April 22, 2013, 05:20:11 pm
I have just purchased the Ultimarc video amplifier to connect at PC to my arcade monitor.
In the description of the video amplifier it says:
The circuitry is exactly the same as that used on the J-PAC and uses a high-bandwidth video amplifier chip..
In the description of the J-PAC it says:
If required, can divide a 31Khz VGA signal in half so that it will display a stable picture on a 15Khz arcade monitor. Useful for checking boot-up progress and configuration (not for application use). Automatically stops dividing the signal when it detects a correct 15Khz rate is being send by the PC.
So, is the video amplifier able to protect my monitor from potentially harmfull 31 Khz signals?
Gray_Area
  • -Banned-
  • -Banned-
I think no. The same in the sense of the signal booster circuit.
-Banned-
