Author Topic: Uneven Picture  (Read 1070 times)
YoBBo
  • Last login:October 01, 2013, 01:17:04 am
Uneven Picture
« on: March 19, 2013, 01:05:38 am »
So I have built a cocktail mame system and installed a LG flatscreen CRT but when I power up the system the picture is warped. It runs off on an upward angle top and bottom and warps on the sides. I thought I might have bumped something when installing but have runs test and all works fine. I even got a portable dvd player running of its battery and plugged it into tv and picture was perfect but as soon as I plug RGB back into video card picture is all messed up again. Hoping someone can point me in the right direction as I am thinking it might be a power or setting problem.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Uneven Picture
« Reply #1 on: March 19, 2013, 10:02:41 am »
Without pictures hard to say.... but as you have now taken a picture tube that normally sits upright and placed it on it's back, it will now see a totaly different magnetic field than what it was aligned in. I am expecting top all to be pushed to the right, bottom to the left. This also depends on what direction the cab is facing as far as North, South etc. Might need a good degauss, might need re-setting of the purity?? Is there signs of discoloration (purity) as well.
Good luck
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Uneven Picture
« Reply #2 on: March 19, 2013, 05:51:07 pm »
the key is it is fine when presented with the type of signal for which it was designed .
check your settings ............
