Author Topic: MAG-Stik Plus joystick issue  (Read 1854 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« on: March 05, 2013, 12:09:18 pm »
Just started doing some initial testing with this stick and I notice if I am pushing left on the joystick and I release just to go to center the game I am playing goes right.  Example "Run and Gun."  If I want to go to the left side of the screen and sit I can go left fine but when I release the left my player wants to run right when my hands are away from the stick.  I can get it to stop by pressing up or down.  Any ideas on how to fix this?  I noticed this also in other games but it really started to show its ugly head in R+G.
Thanks,
Rich
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: MAG-Stik Plus joystick issue
« Reply #1 on: March 05, 2013, 01:07:54 pm »
off the cuff I would say that you should check to see if one of your microswitches is out of alignment and thus causing the issue you are seeing in the neutral position.
rtkiii
« Reply #2 on: March 05, 2013, 04:12:04 pm »
removed the switch and pressed in a lever so it was not extended so far and all seems good now.  thanks for the advice!
Dawgz Rule
« Reply #3 on: March 05, 2013, 06:27:36 pm »
awesome.  glad it helped.  game on.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: March 07, 2013, 12:30:21 pm »
That's the thing about springy close-action stuff. It has....degrees of freedom.
-Banned-
