Author Topic: Cleanstretch vertical only  (Read 16924 times)
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« on: March 04, 2013, 06:38:03 am »
Hi all
Impressed by the results I'm getting with GroovyMAME, seems to work far more neatly than the last time I was impressed (AdvanceMAME, prior to the video rewrite in 107) - smooth scrolling with minimal lag and no sound issues. I'm running on a Rodotron 666A tri-sync CRT, using an onboard Intel chip with a fixed resolution of 640x480. Most stuff I've tried with a resolution of < 320 horizontal pixels scales up nicely with black borders (cleanstretch 1, effect scanlines.png) - impossible to tell it's not a 15KHz CRT, which is what I was hoping for.
Now, my next task is to see if I can run at 768x480, giving me an option for those games that have absolutely massive borders when cleanstretched to 640x480. But even if I fail at this what I'd really like is to be able to simply integer scale vertically ONLY, but scale the horizontal fractionally. I used to be able to do this with AdvanceMAME, but I can't see any way of doing it with GroovyMAME.
I don't want to use true 15KHz modes as the monitor has a far better picture in 31KHz with fake scanlines than it does in low resolution, and I'm not comfortable having it switch between syncs regularly.
Cleanstretch vertical, fractional stretch horizontal, running D3D with filter on should be great for my use. I could probably compile my own binary and hard code the cleanstretch routine to do so, but it's beyond me to modify it more extensively to allow it to be optional ;)
Calamity
  • Moderator
  • Last login:Today at 06:15:36 am
  • Quote me with care
Re: Cleanstretch vertical only
« Reply #1 on: March 04, 2013, 05:14:50 pm »
Hi cools,
Yeah I thought no one would ask for this. It's definitely a required option. Not for nothing AdvanceMAME had it.
A cool alternative to the 'magic' resolution feature, would be creating ridiculously wide resolutions, like 2560 x 224. Then an option like this would allow us to keep the vertical perfectly mapped while fractional stretching on the horizontal for any resolution. No stretching artifact should be noticeable at that ultra high horizontal resolution. This is an old idea by the way. And there's nothing that prevents us to do it.
I will definitely consider it for a future release.
Steps to create a log:
cools
    • Arcade Otaku
« Reply #2 on: March 05, 2013, 05:30:36 am »
Cool, that'd be great. Still have to work out what resolution this one will take, but for anyone with a fixed frequency 31KHz CRT it'll allow for a hugely authentic image.
cools
    • Arcade Otaku
« Reply #3 on: March 10, 2013, 02:15:53 pm »
768x480 is definitely a good choice.
For games that aren't a factor of this on the horizontal, using prescale 2 and filter 1 I *cannot* see a difference between upscaled and native, no need to go to a higher resolution. R-Type Leo for example (320x240) is spot on.
Games that don't scale neatly in either direction are bordered on all sides, but look ugly as hell with cleanstretch off.
Resolution switching is clever, but this is elegant - no monitor collapses when switching res, just looks smooth and meant to be.
cools
    • Arcade Otaku
« Reply #4 on: March 17, 2013, 03:31:44 pm »
Further thoughts. If a vertical game is being played on a horizontal screen, I'd still want cleanstretch on the "vertical" axis of the game display. This would keep the scanlines in the right place running up the screen, and then allow fractional stretch on the other axis to expand it out to the top and bottom of the display while keeping the 4:3 aspect ratio.
cools
    • Arcade Otaku
« Reply #5 on: March 17, 2013, 07:13:08 pm »
Need to get 854x480 to achieve this :)
cools
    • Arcade Otaku
« Reply #6 on: March 18, 2013, 11:00:59 am »
Don't do geometric maths with non-square pixels late at night.
Of course the correct resolution is 1280x480 - if you rotate a 320x240 image without doubling it it'll still be the correct aspect ratio on a 640x480 screen. If you want to double it perfectly you need twice as many pixels on the horizontal  :embarassed:
cools
    • Arcade Otaku
« Reply #7 on: March 19, 2013, 11:11:35 am »
Except for the fact I can't persuade VMMaker to create a 1280x480 mode :(
Calamity
  • Moderator
« Reply #8 on: March 19, 2013, 11:59:18 am »
Just add whatever resolution you want into Resllist.txt, using the exact format. Then launch Vmmaker and it will create the resolution for you.
cools
    • Arcade Otaku
« Reply #9 on: March 19, 2013, 12:45:16 pm »
I've done that. It seems to fall over if the resolution is >999 horizontal and create a nasty interlaced 1264x944 mode.
Calamity
  • Moderator
« Reply #10 on: March 19, 2013, 12:54:40 pm »
Hi cools,
Make sure to use the latest version:
http://mame.3feetunder.com/windows-ati-crt-emudriver/
cools
    • Arcade Otaku
« Reply #11 on: March 19, 2013, 01:05:14 pm »
Aha! :facepalm: I guess this is newer than the one in the driver pack then :)
Calamity
  • Moderator
« Reply #12 on: March 19, 2013, 02:01:36 pm »
Yes, I need to redo the packages with the newer versions in. So did it work?
cools
    • Arcade Otaku
« Reply #13 on: March 19, 2013, 02:35:19 pm »
No, it won't generate a mode at all. I've tried all the different monitor types.
Once I put the xres over 999 it stops trying to make a mode for that resolution. The previous version tried but generated a bad mode.
The largest I can get is 1000, this is by specifying a 999 xres in ResList.txt
My monitor type is set as D9200
Calamity
  • Moderator
« Reply #14 on: March 19, 2013, 03:05:21 pm »
It works here, check my files...
cools
    • Arcade Otaku
« Reply #15 on: March 19, 2013, 03:27:12 pm »
Aha!
I had a space in front of the number, like all the other resolutions. That explains it :)
cools
    • Arcade Otaku
« Reply #16 on: March 19, 2013, 03:32:29 pm »
Success! 1280x480 :)
Next, see if I'm reading the cleanstretch logic correctly in my patch...
Calamity
  • Moderator
« Reply #17 on: March 19, 2013, 03:34:52 pm »
Aha!
Yeah, that's why I said *exact format* because that part of the program is ancient and is so picky with spaces. I'm working in a new version that will be more human-friendly, sorry.
Keep us informed with your custom cleanstretch patch.
cools
    • Arcade Otaku
« Reply #18 on: March 19, 2013, 04:20:44 pm »
Will do. Trying to get MAME to compile at the moment.
The 1280x480 was a no-goer as far as scanlines on vertical is concerned. It may work on a better monitor but on this Rodo/Samsung combo it simply won't resolve them. It won't even resolve single pixel vertical jailbars in 640x480 without horrendous moire so I'm giving up on that for now - was a nice idea but filter 1 seems to cope with scaling artifacts nicely enough so not much point from what I can see.
cools
    • Arcade Otaku
« Reply #19 on: March 19, 2013, 06:11:58 pm »
Struggling. Will try with the 147u3 diffs tomorrow, the 148 diff is producing a result with entirely different behaviour to the official 147u3 compile, even without me messing with it :(
cools
    • Arcade Otaku
« Reply #20 on: March 22, 2013, 07:05:10 am »
Completely failed to work out what was necessary :)
But by playing around with VSTRETCH and VPOS in the Slider Controls menu I've found that I can cleanstretch the vertical manually (using TNZS as an example, disable cleanstretch, set the VSTRETCH to 0.932 and the VPOS to 0.002 and it's perfect). This works fine because we are only ever shrinking the height, we never want to go above the render area - otherwise I could enable cleanstretch and stretch the horizontal manually. The latter would be easier but unfortunately I think I've found a tiny flaw in baseline MAME that Groovy inherits, and now I've spotted it it's bugging the hell out of me.
Set resolution to 640x480, prescale 2, filter 0, cleanstretch 0, keepaspect 1, effect scanlines.png. Run TNZS. Set the vstretch to 0.932 and the vpos 0.002 - this makes the horizontal clean (the scanlines mask any scaling errors, the vpos pushes the error about to be explained into a scanline). Now try and get the vertical to be clean. You can't. There's always one line exactly in the centre of the screen that is doubled. Disable scanlines and you'll see it on the horizontal as well. Setting HSTRETCH to 0.932 should be what's needed but you always get that line, and there's no way of cheating by pushing it into a scanline.
Do exactly the same, but with prescale 0. The errors are gone.
Now, here's the important part as it's where Groovy comes in. Cleanstretch 1, prescale 2. I understand that if cleanstretch is on there should be no need of prescaling, but since we eventually want to enable filtering to eliminate shimmering on horizontal scrolling caused by non-integer X scaling, we definitely need to prescale. Without prescaling we get a lot of undesirable blurring vertically.
Unless I'm very much mistaken, prescaling by 2 and cleanstretching should produce a perfect pixel doubled image. But it doesn't. I'm not sure whether prescale 2 and keepaspect 1 (baseline) should produce a pixel doubled image, but it doesn't anyway.
It's extremely subtle on a big CRT once scanlines and filtering is enabled - an LCD just highlighted the issue to me as I was trying to write up a tutorial :)
lettuce
  • Make It So!
« Reply #21 on: March 22, 2013, 07:18:15 am »
Cools, would enabling HLSL and just using the scanlines mask this issue??
cools
    • Arcade Otaku
« Reply #22 on: March 22, 2013, 07:42:49 am »
No. The HLSL scanlines aren't visible at this low a resolution, and you can see the problem is still there (have to set the HLSL prescale to 4 as filter is always on). If the scanlines were visible it might be an option. For a giggle, use effect scanlines.png and just enable HLSL without any processing...
Calamity
  • Moderator
« Reply #23 on: March 22, 2013, 07:53:24 am »
Hi cools,
I'm assuming you're planning to render tnzs at 480p leaving black borders up and down (448p over 480p).
I'm going to suggest you to give a chance to Groovy automatic option setting, then please report back whether it succeeds or fails. Make a clean mame.ini with the -cc param, then just edit what's necessary to achieve the scanlines effect.
Use the right monitor setting for 31 kHz, for instance: -monitor arcade_31 (forget about the probable geometry variations by now, just a test)
Now, force the resolution option to 640x480, like this:  -resolution 640x480@60
Enable the modeline option: -modeline 1 (please ;))
Now launch tnzs.
I believe it's the -keepaspect option what's messing the picture up.
When the modeline option is active, the prescale right setting is calculated automatically to play together with cleanstretch.
EDIT: Ok, sorry, I didn't notice you're planning to stretch on the horizontal. Anyway, try disabling -keepaspect and play with the stretch factors manually.
« Last Edit: March 22, 2013, 08:00:53 am by Calamity »
cools
    • Arcade Otaku
« Reply #24 on: March 22, 2013, 08:30:30 am »
Okay - I had to manually change to 640x480 before running Groovy (switchres can't find a mode it likes - not surprising as I'm on a test laptop with an NVidia chip, standard drivers and multiple monitors)
Same problem :)
cools
    • Arcade Otaku
« Reply #25 on: March 22, 2013, 02:06:20 pm »
May simply be a bug in the Nvidia driver - I can't get the onboard intel to prescale properly, and the scaling is different on it as well?! The ATI with CRT Emudriver seems to be flawless.
I'd still like to see a proper cleanstretchY option in a future release, but manually adjusting the games for now will be fine - I have to set them all up with freeplay or credit on start anyway!
cools
    • Arcade Otaku
« Reply #26 on: March 22, 2013, 02:47:27 pm »
I may just want to stick to the slider controls... Just realised I can shift games that would double larger than 480 lines up and down the screen. Rtype is perfectly playable if you scale it above 1 to fix the scanlines and then shift it up the screen just enough to make the score visible  ;D
cools
    • Arcade Otaku
« Reply #27 on: March 24, 2013, 06:33:51 am »
Tested on another Intel chip and it works fine, so its just a driver glitch :-)
Calamity
  • Moderator
« Reply #28 on: March 25, 2013, 05:22:18 pm »
Hi cools,
I don't know but this issue might be related with what you're seeing: http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=305258&page=2&view=expanded&sb=5&o=&fpart=1&vc=1
cools
    • Arcade Otaku
« Reply #29 on: March 26, 2013, 10:27:24 am »
Thanks, yes - that's exactly it. Albeit subtly different configurations.
I'm not registered on MAMEWorld, if someone wants to point them to this thread it might be useful for them. I'm happy enough with the ATI solution.
lettuce
  • Make It So!
« Reply #30 on: March 29, 2013, 08:01:09 am »
Apologies for this slight hijack of this thread. I'm looking an an LCD PC monitor that reports in the spec sheet...
Horizontal frequency: 30-94 kHz (VGA), 30-92 kHz (DVI), Vertical frequency: 48-85 Hz (VGA), 30-92 kHz (DVI)
Will this run groovyMAME/arcade games at the correct speed with smooth scrolling? And then use cools method of double refresh and clean stretch for an authentic scanline look? I know cools is working with a 31khz CRT here, but I wonder if I could get the same results with this LCD as it seems unusual for a LCD to support such a wide range of refresh rates?
cools
    • Arcade Otaku
« Reply #31 on: April 01, 2013, 03:03:21 am »
Run an LCD at native res and use HLSL.
You can get good results without HLSL but it'll require setting up every game. I wrote the method in the Arcade Otaku Wiki before HLSL was usable ;-)
lettuce
  • Make It So!
« Reply #32 on: April 01, 2013, 05:02:48 am »
Well the native res is 1200x1600, I though it would be better to run the monitor in its lowest possible res?
Just wondered why you weren't using the HLSL scan line feature and nuts a png effect?
Not sure what settings I want in mame ini for an LCD monitor that can handle such a wide refresh rates?, as I don't think you'd want to set the display as 'LCD' as its not limited by the usual LCD refresh rates
Calamity
  • Moderator
« Reply #33 on: April 01, 2013, 10:15:23 am »
It's not unusual that a LCD accepts a wide range of input signals, what's rare is that it does actually *output* those frequencies, i.e. refresh its panel at the input rate rather than refactoring the signal into the 60 Hz working range. As far as I know LCD manufacturers don't advertise this feature so your only hope is testing it directly or buy one which has already been tested by some user who knows what he's doing. There was a thread in this subforum with some models that did custom refresh rates (Viewsonic?). I don't use LCDs myself for emulators, but considering the amount of LCD users, the fact that we still don't have a list of suitable models is something that's beyond me.
« Last Edit: April 01, 2013, 10:17:34 am by Calamity »
lettuce
  • Make It So!
« Reply #34 on: April 01, 2013, 01:13:52 pm »
Was that the, 'GroovyMame and Vision Pro LCD' Thread??
Well I could not resist and got a used HP LP2065 off ebay for around 80.00 and I have great news. It works!  Mk reports 100% on Mame .. Monitor reports 55hz on vertical and the most important thing is that it scrolls smooth. So I think we have a winner. Couple things to note was once again I had to unistall and reinstall powerstrip because it was not changing the res like it was suppose to when I switched from the Dell to the HP and also to note is that I had to use a DVI-A (a as in analog as in VGA) Because the monitor only has two DVI ports and only the analog signal can go up to 75hz.  The HP I got on ebay had a small scratch/puncture in the LCD so I thought I would see if the DELL panel would fit in the HP and it did. Same harness and everything.  I also tested qbert and that ran at 61.
So it would seem by the result of smooth scrolling that it is actually out putting 55hz
eboshidori
  • Last login:May 20, 2013, 06:56:18 pm
  • Le CRT vaincra ! ^.^
« Reply #35 on: April 01, 2013, 05:48:07 pm »
The fact is LCD is not a suitable display for gaming  :P , so don't expect to get such a list from users who can't see to what extent it's so bad, and deal with it anyway.
Sure, there are (very few) LCDs that aren't as bad as the others, but good luck to find informations on them...  ::)
Quote from: jrose78
That's a good news that it accepts 55 Hz. It can use the timings of the signal rather than the internal PLL. But it's possible that it means an additionnal frame of delay... 1rst frame to wait for the incoming informations, 2nd to perform scaling (unless you provide a 1600x1200 picture), and then be ready to jump in sync with the next frame of the signal. Even if your MAME doesn't have triple buffering enable, your LCD screen is doing it for you ! How nice it is. :P
cools
    • Arcade Otaku
« Reply #36 on: April 02, 2013, 03:26:03 am »
LCD you always want in native, the reason being this (should) avoid any processing being done by the display itself which (a) adds lag and (b) cannot be controlled. You want to avoid adding lag and have complete control over the picture.
The reason I'm not using HLSL is because I'm running on a CRT - this whole thread was about how best to use a 31K CRT. It's completely pointless using HLSL on a CRT, far cheaper to use the standard effect png.
lettuce
  • Make It So!
« Reply #37 on: April 02, 2013, 05:21:29 am »
The only reason I suggested HLSL (just for scanlines) was it gives you much more control over the scanlines than just the effect.png, like scanline brightness, thickness, odd, even all on the fly
cools
    • Arcade Otaku
« Reply #38 on: April 11, 2013, 11:33:30 am »
The only useful one would be brightness, the rest are not useful if you're just linedoubling the image. Quite happy with the default one :)
cools
    • Arcade Otaku
« Reply #39 on: April 26, 2013, 02:41:32 pm »
I'm facepalming hard here.
The ONLY settings that need to be changed (in 147 and 148) from stock config are...
monitor arcade_31
I read a post by Calamity saying that all the expert users seem to be the most distrusting of the modeline option, so I thought I'd try it. He's not kidding. No need for cleanstretch or messing around with vsync, it just works.
