Author Topic: "Bending materials with a simple hot wire forming tool"  (Read 3197 times)
CoryBee
  • Bopity Boopy
« on: February 28, 2013, 05:10:07 pm »
Thought some of you acrylic benders out there would like this read.
http://hackaday.com/2013/02/28/bending-materials-with-a-simple-hot-wire-forming-tool/
shponglefan
Re: "Bending materials with a simple hot wire forming tool"
« Reply #1 on: March 02, 2013, 11:27:33 am »
That's pretty awesome.  I'd be actually thinking recently about how to go about doing more precise bends with acrylic than can be had using a heat gun.
Thanks for posting this!
  • Last login:February 21, 2026, 05:58:33 pm
« Reply #2 on: March 03, 2013, 12:04:38 am »
My problem was never with the bends, it was getting the plastic/acrylic/whatever at just the right temperature.
RandyT
    • GroovyGameGear.com
« Reply #3 on: March 08, 2013, 06:06:54 pm »
That's a good write up.  The spring is very important (as I found when trying this on my own a long time ago) and you can also use an old timey heavy duty battery charger, instead of a battery.  You want to be careful not to get polycarbonate hot enough to smoke when trying to bend it.  The fumes are pretty toxic.
« Reply #4 on: March 08, 2013, 07:08:33 pm »
What does the spring do?
CoryBee
  • Bopity Boopy
« Reply #5 on: March 08, 2013, 08:57:06 pm »
When the wire heats up it flexes\droops, the spring pulls it straight again while it is on.
« Reply #6 on: March 09, 2013, 02:17:54 pm »
Oh, nice.   :cheers:
selfie
« Reply #7 on: March 10, 2013, 07:33:02 pm »
Nice one! The heat is very confined so bending thicker material can be a problem if the wire is too close to the material.
If you are looking at running a longer wire you can step up to an arc welder to power the wire. With a heavy duty ampage regulator the arc welder can run short wires too.
Frequently flipping the material can help with even heating. Also check the distance between the wire and the material
