Author Topic: Think I've done everything rite but no joy.  (Read 1574 times)
fogisgod
  • Last login:March 14, 2013, 07:09:40 pm
« on: February 25, 2013, 02:57:17 pm »
Rite l start from the beginning:
I have bought a old virtua striker arcade machine which I know the monitor is a medium res 25khz. I'm in the process of turning this into a mame cab.
With regards to my PC I have a ATI radeon 9550 graphics card that is supported with soft15khz programme. I have installed the recommended ATI Catalyst 6.5 programme. I have then installed soft15khz and only installed 25khz as that what my monitor is. I then changed the resolution settings to 600x480 as stated.
Then Using a VGA breakout cable I have connected all the right leads from my monitor to the cable. I.e R.G.B horizontal sync and vertical sync. Turn out the pc and absolutely nothing, just a blank screen. There as been on 1 occasion where I can slight see the desktop but was flickering
Badly. What am I doing wrong??????
fogisgod
Re: Think I've done everything rite but no joy.
« Reply #1 on: February 25, 2013, 05:36:41 pm »
Please help. I'm losing the will to live lol.
BobA
  • What Me Worry?
« Reply #2 on: February 25, 2013, 07:43:23 pm »
Sounds like the wrong setting.  VGA is 640 x 480 so 600 x 480 does not sound like med res.   Check what your monitor can display.  A model number and make might help.
fogisgod
« Reply #3 on: February 26, 2013, 08:56:52 am »
My mistake. Sorry i was meant to put 640 x 480.
fogisgod
« Reply #4 on: February 26, 2013, 10:32:54 am »
HORIZONTAL                          VERTICAL
scan frequency: 25.00khz      scan frequency: 60.0 hz
scan period: 40.0 usec           scan period: 16.7msec
Active Video: 32.0 usec          Active Video: 15.4 msec
Video Delay: 7.2 usec             Video Delay: 1.2 msec
Sync Pulse: 4.0 usec              Sync Pulse: 0.2 msec
Scan Line: 640 pixels Screen: 416 lines
resolutions: 512 pixels           Res: 384 lines
Clock Freq: 16Mhz
These are the details of my monitor
Do i need to do anything more then what i have done in the above in order for this to work.
Many thanks
BobA
  • What Me Worry?
« Reply #5 on: February 26, 2013, 11:03:25 am »
640x480 is VGA not med res.  That is why your med res monitor cannot display the picture. The horiz scan freq of your monitor is 25 khz.   A regular VGA monitor is 31 khz.
Try 512x384  for your monitor.
« Last Edit: February 26, 2013, 11:09:56 am by BobA »
fogisgod
« Reply #6 on: February 26, 2013, 11:26:43 am »
This means that i should install soft25khz and run at 512 x 384 resolutions.
fogisgod
« Reply #7 on: February 27, 2013, 03:53:18 am »
Hi there ive got my monitor working fine and now have mame up and running. But now im stuck.
For example if i open up the game 1941 this runs perfect but then if i open up street fighter ii championship edition the screen flickers alot and i can only just see the image in the back ground.
What do i have to do to get other games to work.
Cheers
BobA
  • What Me Worry?
« Reply #8 on: February 27, 2013, 09:55:54 pm »
Sorry I do not run soft anything for my monitors so I would only be guessing.  Glad you are almost there.  Maybe someone with more experience with the program can help with the final setup.
