Author Topic: GroovyArcade live-CD 2020  (Read 666377 times)
-lux-
  • Last login:January 08, 2022, 02:19:32 am
Re: GroovyArcade live-CD New Release 2018
« Reply #760 on: September 17, 2018, 08:05:07 am »
@terranigma: Hi! I'm really interested on Alpine linux solution you just described.
I'm planning to try it soon, so I'd like to ask you a few questions (sorry if this is not the most appropriate place, but maybe there are others interested on):
  • wich emulationstation version do I need to use? Debian based?
  • there's a way to *hide* linux and to have the computer start direcly in ES?
Thanks in advance
terranigma
  • Last login:March 20, 2019, 04:03:17 am
« Reply #761 on: September 28, 2018, 02:49:18 pm »
Thanks in advance
Alpine Linux is not a debian based distro. It is independent. You can install ES along with its dependencies with "apk" package manager.
Code: [Select]
apk add emulationstation emulationstation-theme-gbz35
then
Code: [Select]
apk add mame
if you prefer arcade-only setup, I suggest you to install mame-arcade package instead of "mame" which is bigger in size.
There are many ways to directly launch emulationstation after boot but I think here is not a right place discuss this. YBy saying that, you must also have  a degree of experience on Linux.
« Last Edit: September 28, 2018, 02:54:01 pm by terranigma »
-lux-
« Reply #762 on: October 01, 2018, 07:21:35 am »
Thanks for aswering. I'll give it a try  :)
vaporwaven
  • Last login:February 01, 2019, 08:51:39 am
« Reply #763 on: October 09, 2018, 11:59:56 am »
Hello, I am having an issue with the newest version of groovy arcade arch, in wich the whole frontend, gasetup included is double scanned and boucing/tearing on my Sony 2530 pvm. Running a game or rom runs fine on the tv, but the front end and gasetup screens are like this. I am using a gtx 650 for a video card. Any info on this would be greatly appreciated!
Thanks,
bjt42
  • Last login:February 03, 2022, 06:24:37 am
« Reply #764 on: December 03, 2018, 05:14:02 am »
I have noticed that you are using kernel 4.15.7. From 4.14.x onward, I am experiencing video playback issue with the AMD radeon driver.
I'm also experiencing this issue with the 2018 live CD. Lockup when playing video in AttractMode basic layout and screensaver. I also saw some lockups when traversing AttractMode menus but unsure if they are caused by the same problem.
I installed the 2017 live CD instead which has an earlier kernel and isn't affected. I was able to use the GroovyMame 195 from the 2018 CD after upgrading glibc and a few other libraries.
bjt42
Re: GroovyArcade live-CD New Release 2017
« Reply #765 on: December 03, 2018, 05:29:09 am »
Hello,
I have a new GA version(only for test)
-Experimental Fix Vertical interlaces games [by Doozer]
Would it be possible to get this fix as a standalone patch file? I would like to apply it to the 2017 live CD, as the 2018 version has another issue with freezing during video playback.
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #766 on: December 04, 2018, 02:58:20 pm »
I have answered your PM and provided you with the diff to fix interlaced content.
Just to push bit further the investigation of video playback issue. Playing video using ffplay will also freeze after few dozen of seconds. Are you in a position to confirm this?
bjt42
« Reply #767 on: December 05, 2018, 05:53:34 am »
Thank you, I will report back once I have built and tested a kernel.
I have not tested ffmpeg, only software decoding within AttractMode. Will let you know if I get a chance to try ffmpeg with the 2018 CD.
bjt42
« Reply #768 on: December 06, 2018, 04:37:10 am »
Doozer's patch solved this problem for me, running a 5450. Here is a 4.10.11 kernel compiled with the 15khz patches and this interlaced vblank fix. It matches the kernel supplied with the 2017 live CD and doesn't suffer from the video playback freezing seen in later kernels.
linux-custom-4.10.11-1-x86_64.pkg.tar.xz: https://drive.google.com/open?id=1i3guHlHfWPNrEhwlz6XF2Xs9Ut9-DUmf
linux-custom-headers-4.10.11-1-x86_64.pkg.tar.xz: https://drive.google.com/open?id=19hxL-5RAmNwprpk6ItMDc3A-SegFrit5
Install as root as follows:
pacman -U linux-custom-headers-4.10.11-1-x86_64.pkg.tar.xz
pacman -U linux-custom-4.10.11-1-x86_64.pkg.tar.xz
Then modify /boot/syslinux/syslinux.cfg to point towards the linux-custom kernel and initrd.
keilmillerjr
  • Web Developer.
« Reply #769 on: January 04, 2019, 05:42:25 am »
New year! Is groovy arcade still being maintained? Working with raspbian lite for a pi project has me thinking about groovy arcade.
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #770 on: January 04, 2019, 07:18:53 am »
Ves still releases an update once per year or so, it depends on him having free time.
Steps to create a log:
keilmillerjr
  • Web Developer.
« Reply #771 on: January 19, 2019, 08:02:04 am »
I installed groovymame via virtual box on my mac. Wanted to start playing with it before committing to it on my arcade machine. To my surprise, attractmode and mame run great within a virtual install!
I found issue #13 and followed suggestions to resolve keyboard map. Only difference is that I am using image 2018.03.04 and the line needed to edit was 330. Horay! I can now easily navigate the console.
System Update within the gasetup doesn’t work. Not a big deal. Thought the inclusion of a desktop environment was interesting. Not sure why it would be included.
My end goals is to upgrade attractmode, use haynor666 + groovy patches and compile mame.
Trying to understand the directory structure.
  • ~ has some random mame files in it with an odd path for roms.
  • /usr/local/bin has advmenu, advmenuOld (what is this?), groovymame, gasetup, switchres, and sh scripts (isn’t a binary?)
Why does mame have a weird structure? Where is attract?
keilmillerjr
  • Web Developer.
« Reply #772 on: January 19, 2019, 12:27:43 pm »
CRT shaders through gasetup does not save. Need to investigate.
Removed some emulator packages I definitely do not need. Left LXDE for the time being.
Code: [Select]
$ sudo pacman -Rnsc gens mednafen mupen64plus nestopia snes9x stella yabause-gtk
Found attractmode using the following command.
Code: [Select]
$ sudo find / -name attract
File paths:
attract binary: /usr/bin/attract
attract config folder: /usr/share/attract
mame: /usr/local/bin/groovymame
mame config folder is really messed up. /home/ contains hi folder. mame.ini. This makes sense I guess. No roms folder. Also has other files and folders that are unconventional. /home/emulators/mame ? I don’t know.
keilmillerjr
  • Web Developer.
« Reply #773 on: January 19, 2019, 04:24:36 pm »
Compiled attract-mode 2.5.1. Need to make heads and tails of the multiple directories now.
During install, attract created a new config directory. I removed the old one in /home/arcade/.attract. Launching the attract binary still tries to use the old path. I am not sure why.?
Edit: oomek brought it to my attention that there is a default config path and personalized path, just like on the Mac.
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #774 on: February 02, 2019, 03:10:06 am »
Hi, new version GroovyArcade 2019
Download GroovyArcade
« Last Edit: February 02, 2019, 04:23:21 am by ves »
oxy
  • Last login:August 31, 2019, 09:06:27 pm
« Reply #775 on: February 02, 2019, 03:14:11 am »
Descarga GroovyArcade
Muchas gracias Señor ves!
keilmillerjr
  • Web Developer.
« Reply #776 on: February 02, 2019, 09:57:20 pm »
Hi ves! Thank you very much for maintaining GroovyArcade!
I am testing on virtual box via mac. I had no issues with multiple installs of the 2018.03.04 image. I am having an error after install with the 2019.02.02 image. Once I reboot after install, „Loading ../initramfs-linux.img failed: No such file or directory“ and then drops me to a boot command prompt. Virtual install has 4096mb ram and 16gb dynamically allocated disk. These settings seemed to work well for compiling on the 2018.03.04 image. I have even tried starting fresh, booting to gparted, wiping out the virtual disk, and then installing. Same results.
What exactly changed in this version? How are you creating the image? Perhaps we can somehow get community involvement? I use git for scripts/files. I am not sure what to do for something like this.
ves
« Reply #777 on: February 03, 2019, 03:38:47 am »
Hi keilmillerjr,
Please download again, yesterday I found 2 bugs, now its fixed.
keilmillerjr
  • Web Developer.
« Reply #778 on: February 03, 2019, 04:16:45 pm »
Hi keilmillerjr,
New version boots install from disk now. Thank you! Perhaps update date in filename to differentiate revision.
gasetup still doesn’t save the keyboard map. Please change to the following:
Code: (/opt/gasetup/core/procedures/interactive line:330) [Select]
localectl set-keymap $KEYMAP
Update GroovyMame new website does not work.
Gasetup menu update also fails. Is this something open source we can contribute to and improve?
Thank you again! I really like groovy arcade. :cheers:
eewoke
  • Last login:April 14, 2023, 05:18:23 pm
« Reply #779 on: February 05, 2019, 12:16:40 am »
Great news VES! Thank you very much!!! Please keep working on this version, much appreciated!
b4nd1t0
  • Last login:February 11, 2025, 01:35:18 am
    • b4nd1t0's repository
Re: GroovyArcade live-CD New Release 2019
« Reply #780 on: February 05, 2019, 03:51:46 am »
Thanks Ves!  :cheers:
mmandrea
  • Last login:January 03, 2023, 08:27:07 pm
« Reply #781 on: February 07, 2019, 08:17:23 pm »
I downloaded and installed (to disk) the 2019 version of groovyarcade over the weekend.  I love the concept, and a lot has gone well - but I have a few issues that I need to resolve.
The most critical is that attract mode keeps locking up on me.  This typically happens when I am navigation the configuration menus - but once it happened on the main game menu when I was scrolling through the game list.  I only have about 20 games loaded so far while I get everything set up.  It hasn't happened yet while playing - but this isn't really conclusive since I've been spending the far majority of my time getting it set up so far.  This has happened with a few different themes.
When it locks - the keyboards seems completely unresponsive.  I haven't found a way to recover without powering off.  Are there any logs (or ways to turn on logging) so I can see if there are any error messages?  I have no idea why this is happening and no idea how to begin to try to find the cause.  I have a little linux experience, but am basically a novice.
The other issue I am having (which is far less of an issue until I get the first one resolved) is that I can't get the Nevato theme to work.  I just get a black screen with a large game list.  I just copied the theme from my Windows install which worked fine on the same cabinet.
I'm probably leaving our relevant information - but please let me know if anyone has any suggestions.
Thanks in advance for any help or suggestions.
Mike
mmandrea
« Reply #782 on: February 07, 2019, 09:40:36 pm »
After a bit of playing around and trying different key combinations - I was able to get a dialog that allowed me to end the process.  That kicked me out to a console that briefly displayed a message before re-running GASETUP.  I took a video and extracted an image of the screen.
Hopefully this provides enough info for someone to point me in the right direction.
Mike
oxy
« Reply #783 on: February 07, 2019, 10:00:34 pm »
Type dmesg on the terminal
keilmillerjr
  • Web Developer.
« Reply #784 on: February 07, 2019, 10:47:39 pm »
LXDE -> LXTerminal -> attract
You should be able to scroll back on your log after exiting attract (if I remember correctly).
NaNo1982
  • Last login:March 06, 2019, 09:26:23 am
« Reply #785 on: February 08, 2019, 08:49:38 am »
Yesterday night I tried this new version of groovyarcade, it works perfectly, the only fault I found is that attract mode stops working after a minute starts, sure is my PC problem and I wanted to know what version of groovymame is installed in this compilation, to add the correct roms package, keep up the great work!
Saludos desde Argentina!!
keilmillerjr
  • Web Developer.
« Reply #786 on: February 08, 2019, 09:11:13 am »
You can launch lxde, open LXTerminal, and then launch groovymame without any parameters.
I’m starting to compile mame for GroovyArcade. Can find diffs and binary on my repo. Will do 0.206 soon. Thanks to haynor666 and calamity.
https://github.com/keilmillerjr/mame-diffs
mmandrea
« Reply #787 on: February 08, 2019, 09:17:59 am »
Did this.  Didn't see anything obvious. Am I looking for something in particular?
Thanks.
mmandrea
« Reply #788 on: February 08, 2019, 09:19:12 am »
Will give this a try.
Thanks,
Mike
nexuscab
  • Last login:February 10, 2019, 08:42:59 am
« Reply #789 on: February 10, 2019, 07:55:21 am »
Seems to me an issue with permissions for the Wiki:
There was an error obtaining wiki data:
{"data":{"text":"Anonymous caller does not have storage.objects.get access to google-code-archive/v2/code.google.com/groovyarcade/wiki/USB_installation.wiki."},"status":401,"config":{"method":"GET","transformRequest":[null],"jsonpCallbackParam":"callback","url":"https://www.googleapis.com/storage/v1/b/google-code-archive/o/v2%2Fcode.google.com%2Fgroovyarcade%2Fwiki%2FUSB_installation.wiki?alt=media","headers":{"Accept":"application/json, text/plain, */*"}},"statusText":""}
keilmillerjr
  • Web Developer.
« Reply #790 on: February 10, 2019, 03:48:23 pm »
This only works for the virtual console.
I believe we need a different format for x11 keymap. Perhaps a new menu entry?
MonkeyJug
  • Last login:September 11, 2025, 04:54:07 pm
« Reply #791 on: February 13, 2019, 09:58:32 am »
Guys, I updated groovymame and overwrote the file in /usr/local/bin.  Now when I try to launch GroovyArcade, there is no option for MAME - only the consoles.
I checked the MAME.xml file and it says 0 bytes.
What am I doing wrong?
Cheers.
Calamity
  • Moderator
« Reply #792 on: February 13, 2019, 10:51:43 am »
Probably AdvMenu needs to recreate the xml. For some reason it's not succeeding.
MonkeyJug
« Reply #793 on: February 13, 2019, 12:25:26 pm »
Cheers.
Found the solution here:
http://forum.arcadecontrols.com/index.php?action=post;quote=1539604;topic=147799.0;last_msg=1539703
Courtesy of robbo43
NaNo1982
« Reply #794 on: February 13, 2019, 03:26:24 pm »
Hello, I have another query ... Install the Retroarch emulator and configure it in the advmenu for the Naomi, atomiswave and dreamcast games, also to run some consoles, the swichtres function works fine but the different consoles or arcades set them all in 60,000 hz, would I have to install more custom modelines?
I do not want there to be a conflict with groovymame, which by the way works amazing
Thanks!!!!
b4nd1t0
« Reply #795 on: February 19, 2019, 05:25:12 am »
I'm having a very strange problem, with attractmode, if I enter in the settings to remap the frontend keys, in the button assignment menu after a few seconds everything stops and remains freezed. The only way to go forward is to reset the system, but if I make the changes quickly and go out from the key mapping menu, everything works normally.
Has anyone encountered this problem?
bjt42
« Reply #796 on: February 19, 2019, 07:41:39 am »
Yes I also had this problem. Ended up changing to Windows 7 Embedded due to this and several other issues.
b4nd1t0
« Reply #797 on: February 20, 2019, 03:35:55 am »
Yesterday I did some tests to finish the configuration and I noticed this, if all the setup menus are used without ever pressing the esc key, never crashes, just use the back to go back to the previous menu, I configured everything without problems , creating lists, filters and setting keys, it's worth trying because it's really nice. I forgot, I did everything from LXDE and then set attract again in auto start, just to add roms and multimedia.
MonkeyJug
« Reply #798 on: March 01, 2019, 12:25:54 pm »
Can anyone advise on how to filter my Attract Mode romlist so it doesn't show the thousands of fruit machine and mahjong games please?
Or, can someone send their 0207 romlist MAME.txt file?
keilmillerjr
  • Web Developer.
« Reply #799 on: March 01, 2019, 01:55:29 pm »
Filtering lists
https://github.com/mickelson/attract/wiki/Example-filters
All killer tag list for attract
https://github.com/keilmillerjr/attract-tags
