Author Topic: GroovyArcade live-CD 2020  (Read 649649 times)
MonkeyJug
  • Last login:September 11, 2025, 04:54:07 pm
Re: GroovyArcade live-CD New Release 2016
« Reply #600 on: December 31, 2016, 01:19:59 pm »
There might be more lines associated with the emulators like rom paths, etc. that need to be removed as well.
You could try booting to lxde and running advmenu from a terminal window to see if an error message is produced. That may give a clue as to how you can proceed.
I'll try that! Just in time for my NYE party! :o)
claesbert
  • Last login:March 01, 2017, 12:21:53 pm
« Reply #601 on: January 04, 2017, 03:52:37 pm »
hi, where can I find the latest version of groovyArcade?
thx!
Bert Claes
MonkeyJug
« Reply #602 on: January 05, 2017, 12:20:05 pm »
thx!
Bert Claes
Post 1. Link 1.
pablo79
  • Last login:January 06, 2017, 11:54:47 am
« Reply #603 on: January 06, 2017, 11:54:47 am »
Hi all, I tried to install the last version of GroovyArcade but as soon as I reboot the pc, it gives me GRUB error 17 and I'm not able to solve this issue.
I installed from an USB stick on a SSD and the installation seems to work correctly.
Any ideas to solve it?
Thank you all.
claesbert
« Reply #604 on: January 06, 2017, 03:45:38 pm »
Thx, I thought there was a more recent release somewhere else. so the latest release is from july, right?
thx!
Bert Claes
Post 1. Link 1.
Rupert H
  • Last login:October 14, 2023, 03:53:15 am
« Reply #605 on: January 11, 2017, 05:40:41 am »
Hi guys,
I'm running a Groovy Arcade set-up on a Linux PC but I can't seem to find out which version of the installation I have running. It's also running Linux 3.17, Attract Mode 1.4, and a version of Groovy MAME that I'm unable to confirm. Anybody know where I can check the version of GM?
How can I check which version this is? How do I update it? None of the update options work (for Groovy MAME, Attract Mode, etc) and the update option for Groovy Arcade says "coming soon". How can I get this updated? I can confirm that the PC is connected properly as I've pinged various sites successfully.
Many thanks,
Rupert.
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #606 on: January 11, 2017, 07:32:06 am »
Hi guys,
Many thanks,
Rupert.
You can try to get the version from command line with :
Code: [Select]
groovymame -help
Rupert H
« Reply #607 on: January 11, 2017, 08:14:24 am »
Thanks for your help Doozer. I'll give that command a go for the GM version.
What about checking the GA version installed package? Is there any guidance on how to update this online? This is the first Linux machine I've used and I only have access to Windows hardware.
As you seem to be in the know, could I trouble you with a few broader questions? I understood that Linux was the native environment for Groovy MAME. Is that actually correct? With its low resource requirements and lack of Windows interference, I understood this was the cleanest way to run GM optimally. Reading around here it appears that Windows might currently be the better option in terms of minimising input lag. Are there any other significant differences between the two OS environments? Performance, compatibility, on-going support, etc.
Is the CRT Emu Driver 2.0 only neccassary in the Windows environment or is it required for Linux too?
Thanks again,
Rupert.
Doozer
  • Z80 ERROR
« Reply #608 on: January 11, 2017, 03:33:04 pm »
You can use the following command under GAvto trigger the update process:
Code: [Select]
pacman -Syyu
groovymame is not bind to Linux. GA is only the free live cd based on Linux to allow people to have quickly a full environment to enjoy 15 kHz. Nevertheless, differences exist between Linux and Windows inherent to their design (kernel concept and available libraries). It is true that Windows benefits from a better reactivity (frame delay), on the other side Linux has a smoother driver handling with easy to go 15 kHz with ATI cards. Essentially, it is a matter of fun and how you enjoy your setup.
CRT Emu driver is only required under Windows.
Hope it helps
usermoko
  • Last login:February 02, 2018, 06:27:12 am
Need Help configuring lpt port joystick
« Reply #609 on: January 19, 2017, 07:39:09 am »
Hi to all!
I have trouble connecting lpt port joystick. i am not very familiar with linux so need help. The buttons are connected to the computer lpt port as shown on this link.http://tigerheli.mameworld.info/encoder/pport/trimoor/index.htm. Controls are working great under windows, with ppjoy driver. I see that there is openppjoy driver in GroovyArcade but cannot getting it to work. My openppjoy pc2jamma setup looks like this.
Code: [Select]
parport_pc
#openppjoy map=0,2,3 keyboard key mame default 2 player , map=0,1,1 joystick 2 player...
openppjoy map=0,1,1
#Pc2jamma
#gamecon
Also when i boot into LXDE desktop, there is shortcut to rejoystick which doesn't do anything when i try to start it.
Thanks in advance.
Regards.
Doozer
  • Z80 ERROR
« Reply #610 on: January 24, 2017, 11:16:40 am »
FYI, Arch Linux is moving ahead with preparing to deprecate i686 (x86 32-bit) support in their distribution...
JuniorSierra
  • Last login:May 19, 2017, 08:24:09 pm
« Reply #611 on: January 25, 2017, 10:20:21 am »
Nestopia - Arcade Emudriver. Native resolution.
Rupert H
« Reply #612 on: January 26, 2017, 11:51:27 am »
Code: [Select]
pacman -Syyu
Hi, forgive me if I'm being simple but I can't seem to get this working. I've exited to the Linux command prompt screen and entered "pacman -Syyu". I then pressed enter and it just returns to the line below without activating anything. Am I missing something? I'm a complete Linux noob.
Doozer
  • Z80 ERROR
« Reply #613 on: January 26, 2017, 12:53:13 pm »
Hi Rupert
The distribution has perhaps the repository disabled by default. Edit your /etc/pacman.d/mirrorlist file and uncomment the repository you want. After this, pacman -Syyu shoukd work fine.
Cheers,
Doozer
  • Z80 ERROR
« Reply #614 on: January 26, 2017, 12:54:56 pm »
Hi Ves,
In your next release could you please add openbox window manager? You can PM me for details.
Cheers,
Rupert H
« Reply #615 on: January 26, 2017, 01:08:39 pm »
Hi Rupert
Cheers,
Thanks Doozer,
I tried again and this time I got a message saying "you cannot perform this operation unless you are root". How do I get root access?
As for your suggestion of editing the mirror list file, how do I open this in Linux?
Doozer
  • Z80 ERROR
« Reply #616 on: January 26, 2017, 02:17:41 pm »
To become root you can try the following command with password <arcade> I guess:
Code: [Select]
su -
Otherwise, if not working, try with sudo form shell:
Code: [Select]
sudo pacman -Syyu
Under Linux you have several text editor in command line vi, vim, emacs, pico.... each of them with specific shortcut for cammands. Try them and kerp the one that better suit you editing style ;-) I personally use vi.
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #617 on: January 28, 2017, 05:20:11 am »
Hi Ves,
Cheers,
Hello Doozer.
In previous versions (2014-2015?¿?¿?), openbox was configured.
If you configure openbox, you have delete all contents from file lxde, if it is not configured you will have problems with the special keys ctrl, alt .....
The problem is not mame, linux etc the error is attrachmode configuration, I have fix for attrachmode.
 I'll post it soon.
« Last Edit: January 28, 2017, 05:24:55 am by ves »
pnauts
  • Last login:May 06, 2017, 04:01:58 am
« Reply #618 on: January 29, 2017, 04:10:52 am »
Hi,
I'm new here.
I just DL the last live CD release and after installation, frontend never display , I always go back to the set up main menu.
whatever the frontends I choose, it never works.
My configuration is mainboard Intel Atom D2500
no video card.
I use an old CRT Dell monitor and I chose the proper one I think (CRT VGA 31KHZ 120HZ).
I run to the console and Xorg log indicates a "no screens found"
I suspect the Driver is not present ?
(Intel Corporation Atom Processor D2xxx/N2xxx Integrated Graphics Controller).
I try some Fresh Debian install and Mame set up and it's works.
thank you for your help.
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
« Reply #619 on: January 31, 2017, 07:39:12 pm »
Look at the dmesg output. It should give you the error / driver names etc for troubleshooting.
keilmillerjr
  • Web Developer.
« Reply #620 on: February 02, 2017, 12:48:32 pm »
Would anyone want to do a video tutorial on setting up groovy arcade on crt, transferring files, installing attractmode and specific versions of groovymame? That would be excellent for non Linux users.
pnauts
« Reply #621 on: February 02, 2017, 06:44:56 pm »
Yes it gives me some error.
for sure it's related to Xorg, I looked at it log file and there is the "no screens found" message.
Had GM ever been tested successfully on ATOM mainboard ?
for the moment I can set a Debian OS with Mame and Attract Front End.
I will not erase it to test GM but I'm curious about fix and I'll give it a try with another HDD if I can have support.
« Last Edit: February 02, 2017, 06:46:44 pm by pnauts »
keilmillerjr
  • Web Developer.
« Reply #622 on: February 05, 2017, 04:02:21 pm »
I installed GroovyArcade on my mac using virtual box. Network using NAT mode and it fails. After setting up „eth0“, it hangs. Pressing tab a few times gets me out. I go to update -> GroovyMAME Update and either new or old site only shows the option of cancel. I copy disk image to a thumb drive using unetbootin and install it on a laptop I have. Wired it via ethernet directly to router. Network still does not work. Any ideas?
keyboard map won’t change from es to us as well.
pnauts
« Reply #623 on: February 06, 2017, 04:30:21 pm »
I updated my xorg.conf with:
vesa, it works, very small screen displayed
Fbdev, it works better
so what's the trouble with the Intel driver ?
need to be updated or options in conf file have to be added ?
for memory it's a atom mainboard D2500HN.
Calamity
  • Moderator
  • Last login:Today at 05:35:07 pm
  • Quote me with care
« Reply #624 on: February 07, 2017, 04:48:38 am »
Hi,
I'm new here.
no video card.
Does it work when booting from the live-CD?
Steps to create a log:
pnauts
« Reply #625 on: February 07, 2017, 08:05:04 am »
No, it doesn't.
My test with drivers changes was done after with live configuration.
Calamity
  • Moderator
« Reply #626 on: February 07, 2017, 08:13:01 am »
No, it doesn't.
Have you gone through the monitor setup section in GA menu before testing?
pnauts
« Reply #627 on: February 07, 2017, 08:59:17 am »
Yes, by the way, it's mandatory if I remember well because I did try to launch directly, but there was a popup to redirect to video settings.
Calamity
  • Moderator
« Reply #628 on: February 07, 2017, 12:35:22 pm »
Then probably the distro doesn't contain proper drivers for your GPU. I'd recommend doing a bit of research about this in Linux forums.
pnauts
« Reply #629 on: February 08, 2017, 02:54:54 am »
So what you suggest is to apt-get the missing driver (if I found it) ?
Do you involved in development of GM ?
edit: it seems more complicatad.
I found this for Ubuntu
related to cedarview, but after I found this for Arch
...I don't know what to do.
So I go back to one of my question, can I modify the xorg.conf and keep VESA or FBDEV ?
Is it enough to set up a CRT Groovy Mame distro with a Nanao CRT ?
« Last Edit: February 08, 2017, 03:17:58 am by pnauts »
ozfalcon
  • Last login:November 30, 2025, 12:40:52 am
  • ZSystem
« Reply #630 on: February 08, 2017, 03:58:25 am »
It may be that the xf86-video-intel driver does not support your chipset.
(Description notes:  Intel i810/i830/i915/945G/G965+ video drivers)
..... Just read some of the link you gave.
I think this just about sums it up (Why the intel drivers don't support that chipset).
That's because it isn't their GPU. It's, as I said, a PowerVR design. Owned by Imagination Technologies, and they're totally *not* open-source friendly.
I'd be looking at an add in card - Specifically one supported by GM.
« Last Edit: February 08, 2017, 04:32:46 am by ozfalcon »
pnauts
« Reply #631 on: February 08, 2017, 07:58:50 am »
Yes I saw the chips seems not developed by Intel, but it doesn't mean that it can't be supported by any retro engineering ways.
And about specify another driver like Vesa or FBDEV, which is the better ?
and after I chose one, will the xorg.conf not rewrite according to roms ?
if it just the modelines but not the driver, it could works (perhaps not for some resolution)
edit: according to the datasheet
the driver to use is mode settings for Intel GMA 3600.
I will give it a try.
« Last Edit: February 08, 2017, 08:26:29 am by pnauts »
ozfalcon
  • ZSystem
« Reply #632 on: February 08, 2017, 05:23:59 pm »
Have you read this & it's links
https://wiki.archlinux.org/index.php/Intel_GMA_3600
Your best bet are the Ubuntu & Arch Linux forums to find solutions others have made.
https://wiki.archlinux.org/index.php/xorg#Driver_installation
vesa (xf86-video-vesa), the generic driver, which handles a large number of chipsets but does not include any 2D or 3D acceleration.
It would still be simpler to get a graphic chipset that is supported by Linux drivers and or GM.
pnauts
« Reply #633 on: February 08, 2017, 08:01:53 pm »
Yes, changing the mainboard is the easy way.
would this one will be fine for GM and working out the box ?
http://www.asrock.com/mb/Intel/D1800B-ITX/
pnauts
« Reply #634 on: February 09, 2017, 03:00:15 am »
I forgot to precise but I want to stay with Linux based OS.
ozfalcon
  • ZSystem
« Reply #635 on: February 09, 2017, 11:17:10 am »
This uses Intel® 7th generation (Gen 7) graphics, So it should be ok.
But double check if there are any issues with Linux & Gen 7 chipsets before you commit to it.
Calamity
  • Moderator
« Reply #636 on: February 09, 2017, 11:22:39 am »
I think I'm missing something. Why changing the mother board instead of just plugging in a supported video card?
pnauts
« Reply #637 on: February 09, 2017, 11:52:26 am »
I think the price will be the same whatever I choose.
But mechanically for put in a cabinet and an easy fixing, I prefer the mainboard only than adding another PCB right angle mounted on the main.
Calamity
  • Moderator
« Reply #638 on: February 09, 2017, 11:57:54 am »
But Intel graphics are the worst thing you can use for this hobby. I don't think it will even work for custom video even with the correct drivers. If you're planning to use integrated graphics, you should look for an AMD APU (make sure the chipset you choose is supported by Linux open source drivers).
pnauts
« Reply #639 on: February 09, 2017, 02:57:06 pm »
thanks for the advice. with AMD APU 15KHz is possible ?
is there any website to check that kind of stuffs ?
« Last Edit: February 09, 2017, 02:59:11 pm by pnauts »
