Author Topic: What controller board is needed? Please help  (Read 1661 times)
toopack2
  • Last login:February 28, 2013, 10:57:36 pm
« on: February 20, 2013, 11:51:15 pm »
Hi all,
I am building my own joystick and I want to use it on Playstation 3 console.  What controller board is needed to play on PS# (Playing both PS3 and PC is a plus)?
I don't know if the cthulhu board and zero delay encoder board will work on PS3 or not, even though the PS3 use USB port for its controller.
By the way, I want to play JAMMA games later on and would l need to change to different controller board? what is it? or is there and adapter allowing you to play with YOUR "recommended board"?  Thank you so much
jmike
Re: What controller board is needed? Please help
« Reply #1 on: February 21, 2013, 07:25:48 am »
Hi all,
cthulhu board and zero delay encoder board will both work on the PS3. I've used both. The problem with the zero delay encoder is that it doesn't have a "Home" button support for the PS3. I would recommend the ZD ReMatch Encoder, it has the "Home Button", plus comes with wiring.
Cthulhu boards don't come with the wiring and are slightly more expensive. Check this post, Vigo should be back this month from vacation. I've bought several ZD encoders from him in the past.
http://forum.arcadecontrols.com/index.php/topic,116490.0.html
toopack2
« Reply #2 on: February 22, 2013, 12:59:54 am »
Thank you very much jmike.
Your information is greatly appreciated, good stuff.
