Author Topic: What's the difference between these Seimitsu joysticks.  (Read 5825 times)
cigardude
  • Last login:December 20, 2017, 01:29:48 pm
« on: February 18, 2013, 04:21:43 pm »
I see Seimitsu LS-32, Seimitsu LS-32-01 and Seimitsu LS-32-02 advertised. What's the difference between the three?
shponglefan
Re: What's the difference between these Seimitsu joysticks.
« Reply #1 on: February 18, 2013, 04:27:07 pm »
The mounting plate.  LS-32-01 comes with an SS mounting plate for bottom mounting.  The LS-32-02 comes with a flat mounting plate designed for top mounting.
  • Last login:Yesterday at 05:02:05 pm
« Reply #2 on: February 18, 2013, 05:07:32 pm »
The -01 and -02 come with a PCB for the microswitches and use a 5-pin connector for fast and easy replacement in arcades. The LS-32 comes with regular microswitches.
-01 PCB:
And yes, the LS-32 comes with the flat RE plates and the 32-01 comes with the "S-shaped" SS plates. IIRC, the 32-02 comes with the -01 PCB and the RE plate?
cigardude
« Reply #3 on: February 19, 2013, 02:35:50 pm »
Interesting, thanks.  :cheers:
