Author Topic: Trackball Button connection to IPAC2  (Read 2027 times)
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
« on: February 17, 2013, 01:39:11 am »
I have a 3" Happ trackball that I connected to a Trackball PS/2 Adapter I purchased from mikesarcade.com. The adapter has three cables that need to be connected to buttons. Should these be connected to the buttons labelled 1SW1, 1SW2, 1SW3, on my IPAC2?
BobA
  • What Me Worry?
Re: Trackball Button connection to IPAC2
« Reply #1 on: February 17, 2013, 02:09:24 am »
The cables need to be connected to the NO and COM of regular arcade buttons.  They do not attach to an IPAC as the adapter you got from Mikes arcades should convert the button presses to mouse clicks.
MamedInCanada
  • Still Learning...
« Reply #2 on: February 26, 2013, 03:31:10 am »
Thanks...I think I worded the question wrong. I have three wires for three buttons for the trackball. They would be left click, right click, and scroll.
Should I drill three holes for these and put buttons in and connect the three buttons to the trackball adapter?
Or can I attach the wires to three existing buttons? Attached to the IPAC2.
  • Last login:Today at 05:29:30 pm
« Reply #3 on: February 26, 2013, 04:15:57 pm »
There are two ways to add a mouse button:
1. Connect the mouse button wire from the adapter to a pushbutton.
Mouse button input  ___/ ____  Ground
2. Connect the IPac to the button. (new firmware version, input programmed for mouse)
IPac input  ___/ ____  Ground
Of courwse, you could do it wrong and risk messing up both boards by wiring it like this.  >:D
Mouse button input  ---|
                                   |___/ ____  Ground
              IPac input  ---|
