Author Topic: VGA to DVI Adapter  (Read 1086 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
VGA to DVI Adapter
« on: February 08, 2013, 09:00:01 pm »
I got a DVI monitor, I bought a VGA to DVI adapter cord and it doesn't work.  No signal found.  So it's not just as simple as buying the adapter cable?  Am I missing something?
Thanks for your help,
-SP
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
Re: VGA to DVI Adapter
« Reply #1 on: February 08, 2013, 09:21:03 pm »
-SP
It's tougher than that man.  You're trying to go from an output that's analog to an input that's expecting a digital signal.  Although it's simple to use the little plug on adapters to connect onto a video card in a pc that has only DVI output so you can use it with an older VGA (15-pin connection) monitor, the other way around would require some type of special converter.  If you have an expansion slot in the pc to install a new video card with DVI output, that would be your BEST/CHEAPEST solution.   :cheers:
southpaw13
  • Whatever!
« Reply #2 on: February 08, 2013, 10:12:49 pm »
Thanks....makes sense.
-SP
