Author Topic: JVL Systems PDF Manuals and info.  (Read 19047 times)
lilshawn
  • Moderator
  • Last login:July 04, 2025, 12:24:07 pm
« on: February 08, 2013, 01:58:44 pm »
Will copy paste links to info sorted by generation here:
"iTouch" series systems:
iTouch "HD" series systems:
oldgrandpainmi
  • Last login:July 10, 2020, 08:48:17 am
Re: JVL Systems PDF Manuals and info.
« Reply #1 on: July 09, 2020, 11:32:57 am »
do you have any links to manuals showing how to remove the touchscreen/display from a JVL Retro?
lilshawn
  • Moderator
« Reply #2 on: July 14, 2020, 12:10:35 pm »
I don't unfortunately the data surrounding JVL is extremely scarce...and only supplied by the manufacturer on a need to know basis.
for the retro, i believe there are 2 phillips screws on the inside in the top and right corners (and a latch maybe?)  the monitor should hinge out if you push it out from the inside.
use caution, it is only held in by tabs at the bottom so you can lift it up and out. so don't go all gung ho tilting and flipping it around.
game_nerd
  • Last login:June 18, 2024, 08:38:27 pm
« Reply #3 on: May 12, 2022, 03:29:32 pm »
I did find a bmi gaming manual for the echo/encore. it's got some illustrations and part numbers for apparently non existent replacement parts.
maybe it will come in handy
sodonivhd
  • Last login:July 18, 2024, 08:48:54 am
« Reply #4 on: July 13, 2024, 03:35:37 pm »
hello i recently got my hands on an old JVL 20 from an Eclipes JVL touch coin operated game i'm getting a D2 code and a D3 i've tried multiple sets of ram and this still just throws the code give me really loud beeps and no signal any advise?
« Last Edit: July 13, 2024, 03:40:10 pm by sodonivhd »
hurdy
  • Last login:March 09, 2025, 04:11:56 pm
« Reply #5 on: March 09, 2025, 03:08:49 pm »
Here's a youtube video of the JVL teardown....
