Author Topic: So, no new 25" tri mode digital CRTs available?  (Read 3375 times)
Dcpmark
  • Last login:February 02, 2026, 12:29:09 pm
« on: February 04, 2013, 10:06:42 pm »
Ok, I'm still rocking a 21" Hitachi Multisync from 1996 in my cab. From my reading here it seems that I'm looking for some Holy Grail in MAMEing.....a tri mode 25" digital monitor that can automatically switch resolutions and remember settings.
What models should I be looking for to buy used as I start scouring eBay and Craigslist?
Thanks in advance!
« Last Edit: February 05, 2013, 08:36:29 am by Dcpmark »
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: So, no new 25" tri mode digital CRTs available?
« Reply #1 on: February 05, 2013, 12:00:58 pm »
Yes, you are right! I believe we talked this morning!
As I mentioned and am repeating this for others..
- no the 24.8" or 25" tube has been out of production for some time.
- you may be lucky to find a distributor that has had stock sitting for some time, but not likely.
- Yes if you are using Mame and want to switch between all the Native resolutions ( CGA and mid res) to VGA then it is a must to be digital. That is why any time we sold our tri-res to someone running Mame we cautioned them to stay in one resolution. Preferably 640X480 -31Khz-VGA. This will avoid the need to make many adjustments to size and position etc. when changing resolutions.
- When going the LCD route if you want to do all the resolutions, beware that many LCD's (especially retail) do not accept them... in fact as "Standard res" is not really "standard" select one that does 15.1khz to 16.3Khz.
Be sure you have a good viewing angle,brightness and contrast. Of course response time need to be fast, be careful there as it is quoted in many ways. Sometimes just rise, rise to fall rise to video and on and on.
- Also be sure you can adjust picture size position etc and store them, many LCD's do not.
Hope this helps all, we are very proud of our product and yes it is more expensive than a retail LCD, but they do all that. Open frame and idustrial grade.
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: February 05, 2013, 12:54:46 pm »
No CRTs are being made.  25" digital multis were kind of rare. Read about monitors in the Wiki.
-Banned-
Dcpmark
« Reply #3 on: February 05, 2013, 01:01:03 pm »
Thanks for imparting your time and knowledge this morning, Rick! The great search begins, but if it fails and my current CRT fails, I'll be back for an LCD.
Dcpmark
« Reply #4 on: February 05, 2013, 01:07:24 pm »
Yeah, I knew that, but I was hoping someone knowledgeable would post specific brands/models to search for used. Some of the descriptive info makes it hard to tell if it's a tri mode or dual mode, or if it's analog or digital.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: February 08, 2013, 03:08:43 pm »
Just get a presentation monitor. Loads more of 'em were made, they're build like tanks, and often they're pretty cheap.
-Banned-
Dcpmark
« Reply #6 on: February 09, 2013, 09:10:41 am »
A couple of follow up questions, if you don't mind. What's the difference between a regular monitor and a presentation monitor? I tried googling it, but nothing stood out. Are some 25" presentation monitors capable of 15k? If so, do you know of specific makes and models I should be looking for?
Thanks for your help!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #7 on: February 11, 2013, 07:19:32 pm »
Monitor wiki......
-Banned-
Dcpmark
« Reply #8 on: February 12, 2013, 03:56:35 pm »
Monitor wiki......
Actually, the wiki wasn't much help for 25" monitors. But I did find this, which gives me some specific model numbers to look for:
http://amigarealm.whdownload.com/AGAMonitors.htm
krick
  • Gotta have blue hair.
« Reply #9 on: February 13, 2013, 09:44:08 am »
That's absurd.  The whole point of running MAME on an arcade monitor is to get true low resolution output.  If you're going to lock it into a single resolution, you should just use a PC monitor or an LCD (or possibly even a TV), not an arcade monitor.   Buying a $500+ tri-res arcade monitor and only running it at 640x480 is a crime against nature.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
rCadeGaming
  • Just call me Rob!
« Reply #10 on: February 13, 2013, 08:12:44 pm »
+1 Krick
« Last Edit: February 13, 2013, 08:39:50 pm by rCadeGaming »
Gray_Area
  • -Banned-
  • -Banned-
« Reply #11 on: February 14, 2013, 03:14:41 pm »
Monitor wiki......
It answered last question about monitor types.
There used to be a chart like that in the wiki. It's around here for sure; I posted it within the last month or so.
-Banned-
Dcpmark
« Reply #12 on: February 14, 2013, 05:18:09 pm »
Monitor wiki......
Yeah, I saw the reference link in the wiki, but the linked site is now dead. I'll hunt for it here, but if you stumble across it, please post it again. Thanks!
