Author Topic: Servo Stick and LED-Blinky (in Hyperspin)  (Read 14265 times)
Endprodukt
  • Last login:January 25, 2026, 09:19:54 am
« on: February 01, 2013, 03:08:24 pm »
LedBlinky is supposed to work with the Servo Stick but it just doesn't switch between 4/8-way. I activated it through the led blinky configurator under "misc" but it's still not switching. Am I missing something?
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Servo Stick and LED-Blinky (in Hyperspin)
« Reply #1 on: February 07, 2013, 12:18:52 pm »
Hi,
Turn on the Debug Log and Verbose options (on the Misc Options tab), start your FE and run a game or two that should be 4-way and 8-way. Email me the debug.ZIP file and I'll take a look.
Robots will kill you.
Arcade Addiction
Endprodukt
AW: Servo Stick and LED-Blinky (in Hyperspin)
« Reply #2 on: February 08, 2013, 11:15:23 am »
Its working now, thanks :)
« Reply #3 on: February 08, 2013, 12:17:02 pm »
Please share what the issue was. Might help out others some day.
Endprodukt
« Reply #4 on: February 08, 2013, 12:48:34 pm »
I'm not sure actually. I activated the servo stick in the ledblinky config and it didn't switch. I tried the software from ultimarc and it worked right away but still not through led Binky and hyperspin. It worked after a system reboot just fine. I had to adjust my default configuration for mame to 8 way Joysticks and set it to primary so any unknown game would use it. I really like that ledblinky sets to 4way in hyperspin :)
