Author Topic: Ideas for Zombies ate my neighbors lightguns  (Read 5221 times)
cipriani2k
  • Last login:March 27, 2024, 05:58:18 pm
  • All I want is everything.
« on: February 01, 2013, 12:03:46 am »
Hello, I'm currently building a zombies ate my neighbors cabinet and I wanted to make themed lightguns to go with it. I went with the Ultimarc light gun kit and have everything working with that. The page with the kit is below, didn't have a direct link but you can figure it out, it's the kit.
http://www.ultimarc.com/JShopServer/section.php?xSec=7
But I wanted to make 2 light guns that looked like the squirt guns from Zombies Ate My Neighbors.
So it's a pretty basic jumping off point, but I was wondering if anyone had any ideas of a product to kinda build off of or even a scratch build starting point? I'd like to have something with a decent weight to it and it's kinda hard to get a squirtgun like that. If possible, I've got no ideas in mind, I kinda wanna put an led in the gun and have colored water for each one.
Any ideas at all welcome. I feel like there are some cool possibilites, I'm just at a loss on where to start.
  • Last login:January 30, 2026, 08:37:10 pm
Re: Ideas for Zombies ate my neighbors lightguns
« Reply #1 on: February 01, 2013, 02:22:23 am »
Do you have to have it transparent or opaque?
You could try checking out the Toys R Us and see what you can find there for guns you can gut out and wire an aim trak into.
Super-soakers? Nerf guns? Regular water guns might feel cheap and easily broken, but you might be able to find something higher quality.
cipriani2k
« Reply #2 on: February 01, 2013, 04:43:10 am »
Found this for $13, gonna try it out and see how it goes. Seems really close so long as I can clean up that stupid orange part. It'll work fine I'm sure but I still don't know if I can get a water system going. We'll see.
cipriani2k
« Reply #3 on: February 07, 2013, 02:27:52 pm »
So my guns came in today and there is no apparent way to take them apart. I guess I was hoping for screw holes but that was pretty optimistic. Does anyone have an idea on how to get it open? I'm thinking maybe there's a tool fine enough to get in between the 2 pieces of plastic and cut the braces so I can get at the insides. Any suggestions would be terrific, of either a tool fine enough to do the job or a different idea altogether. Thanks in advance :)
Other than that little issue, they look and feel awesome. Heavy plastic, nice resistance on the trigger, big enough size. Good stuff.
jammin0
« Reply #4 on: February 07, 2013, 03:12:38 pm »
dremel with a metal disc or cutoff tool? :dunno
If it isn't attached with screws it has to be held together with glue.  You could try a heat gun but what melts first, the glue or the plastic?  You could probably use bondo on them after the fact if it gets too rough getting them apart.
SithMaster
« Reply #5 on: February 07, 2013, 04:45:21 pm »
I'd rather not suggest a Nerf product (long standing grudge against hasbro) but the tornado strike maybe if only for the easy to disassemble construction and its resemblance to the machine pistol(?).
edit-Amazon pic was swapped with a goggle pic due to overwhelming size messing with the topic width.
« Last Edit: February 07, 2013, 04:48:23 pm by SithMaster »
shazamn
  • Last login:August 16, 2025, 11:34:33 am
« Reply #6 on: April 03, 2025, 09:16:24 pm »
Hi, Were you able to make the model for the zamn lightguns? I'd like to know if, because I'd like to make ones too. Thanks.
