lilshawn,
Is there a reason the MOSFET would stop switching, or is the MOSFET itself possibly bad? I still need to test L108 for voltage, unless it doesn't really matter right now since none of the large diodes in the power supply section are getting power.
When testing the chassis, does it need to be hooked up completely and the anode attached to the tube or can I power up the chassis outside of the game? I have always re-hooked everything back up before powering up the chassis. Thinking back to when I pulled the board to check the HOT, I did forget to attach the anode cup to the tube when I hooked everything back up and it sparked against the metal frame that the chassis mounts to
![Talking to you is like banging your head against a wall! :banghead:](http://newforum.arcadecontrols.com/Smileys/default/banghead.gif)
After this incident, no more power at the big diodes...
