Author Topic: can i have a 60 in 1 vertical board and a 19 in 1 horizontal board in the same c  (Read 2341 times)
mebronx2000
  • Last login:August 03, 2024, 06:20:32 pm
can i have a 60 in 1 vertical board and a 19 in 1 horizontal board in the same cocktail cabinet ? i have a cocktail cabinet with 2player head to head and a 2 player joystick on the side ! if any one has done this or knows please help thanks
Quoted, just in case...
Shouldn't be a problem if the P1 and P2 controls on the sides are wired in parallel with the P1 and P2 controls on the ends. Either use a 2-in-1 JAMMA switcher or manually move the connector from one board to the other when you want to switch.
One question though, with a collection as vast as yours and questions like you've posted... who has done the technical work to all of those machines in the past?
« Last Edit: January 29, 2013, 08:58:10 pm by Nephasth »
mebronx2000
thanks so much ! the things i buy already made i have an arcade technician do all the work and the things i built myself i learn from here and do it myself ! and i hire the people like i have one guy coming all the way from vegas to set up my vp pin even though it was working fine but i like the way he set up his !
« Last Edit: January 29, 2013, 09:47:01 pm by mebronx2000 »
Well, if you ever want to fly me to NY... ;D
mebronx2000
i will keep you in mind ! i already spent $1000s for pcs from this guy and all he has to do is come and set everything up in my cabs .. he will set up my vp pin and he will also setup the hyperspin with the controller and then one just for shooting games using hyperspin in a 6 gun select cab
jmike
Sweet, then you can stop by NJ and help me out  ;)
mebronx2000
what help do you need ? and what part of nj ?
jmike
I live in Bergenfield NJ (about 15-20 minutes off the GW bridge.)
Actually Nephasth has been kind enough to send me directions on how to set up my LED WIZ, on my cocktail arcade.
(btw Nephasth,  the PC I was using died so my friend is building another one for me right now)
Well, let me know when you get it going or need some more direction. :)
jmike
Awesome. Will do.
Thanks Nephasth     :cheers:
