Author Topic: Help with couple problems with Stern Nine Ball restoration (RESOLVED)  (Read 3845 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Hey All,
I've been restoring a Stern Nine Ball and have just two remaining issues.
The first is that the left slingshot bumper won't work. The solenoid fires during the test, so this must be a switch issue. I've traced the wire back to the connector on the MPU board and all seems fine.  Any suggestions on what to try?
The second issue is a bit embarrassing - this pin has a non-active pop bumper and I need to change the bulb. Problem is, for the life of me I can't seem to figure out how to get the top cap off. There are no screws. I would assume it's just held on with friction or I must be missing something obvious. Any ideas?
Resolutions:
The cap was glued on - had to partially crack it to get it off.
One of the sling shot switches had a short - while fixing another connection, some solder dripped onto the base of the leaf switch (across the non-conductive spacers) effectively shorting the switch in the closed position.
« Last Edit: January 29, 2013, 09:56:05 am by arzoo »
Robots will kill you.
Arcade Addiction
Ken Layton
  • Guru
  • Technician
Re: Help with couple problems with Stern Nine Ball restoration
« Reply #1 on: January 27, 2013, 11:06:03 pm »
That cap should be a snap fit. Just rock the cap gently as you lift it off.
arzoo
    • LEDBlinky
« Reply #2 on: January 27, 2013, 11:45:14 pm »
Turns out the cap was glued on. I was able to remove it with only minor damage (small crack).
Arcade Addiction
  • Last login:June 22, 2025, 04:57:38 pm
« Reply #3 on: January 28, 2013, 09:01:08 am »
That happens a lot.  The cheapo tabs break on those caps and people glue them back on.  In the long run it's best to replace those broken caps in a restoration.  Fortunately this one isn't a super expensive one like in a Fathom or Xenon.
When you say "traced it back and the switch wire is fine" do you mean to say you checked continuity or you eyeballed it?
TopJimmyCooks
« Reply #4 on: January 28, 2013, 09:30:18 pm »
change that pin on the connector - or trace continuity through that wire/connector/trace on the board to the TIp transistor.  diode check the driver board transistor.  Even if it tests ok they are sometimes bad - replace if unsure.  Past the transistor to the chip I'm out of my board repair depth.
arzoo
    • LEDBlinky
« Reply #5 on: January 29, 2013, 08:33:54 am »
Yes - I had traced it all back. Turns out there was a short, so the switch was in the closed position as far as the MPU was concerned. Thanks, for the help.
Arcade Addiction
Re: Help with couple problems with Stern Nine Ball restoration (RESOLVED)
« Reply #6 on: January 29, 2013, 09:23:26 am »
Could you provide details on the short so the solution sits in the same thread as the question?
